  • 2Hääli - 3 keskmine
Mercedes-Benz 260 E, 1989, w124 - rannooo
Eelmise aasta suvel ostsin (vahetasin) endale selle Mercedes-Benz. Vahetuskaup sai tehtud vana Audi 100 -83 sigari vastu. Kuna eelmine omanik autodest suurt ei jaganud, siis oli vahetuse põhjuseks Mercedes-Benz "mittetöötamine". Hiljem pajatan sellest pikemalt.
Dokumentide väljastamise kuupäev on 06.06.2009, seega pole ta veel aastatki minu käes olnud.
Mõned andmed
Kood:
Esmane registreerimine 01.01.1989
Registreerimine Eestis 17.07.1996
Töömaht 2597 cm3
Võimsus 118kW
Automaatkast
Tempomat (püsikiiruse hoidja)
ASD
ABS
2x elektriaknad
kesklukk
Andmed VIN koodi järgi:
Kood:
VIN     WDB1240261B070988
Model     260 E
Chassis     1240261B070988
Engine     103940 12 069712
Transmission     722409 02 813759
Order     0 0 239 70129
Lights     HELLA
Wiper     SWF
Cab     10060
Delivery date     89.08.25
Dealer     Ulm branch (239)
Interior     fabric black+anthracite (071)
Paint
122     mother of pearl grey metallic (с 01.01.1986)
Options
211     automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
240     outside temperature indicator (с 01.03.1982)
243     sports seats, front and rear (с 01.12.1986)
281     trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
412     electric sliding roof with tilting device (с 01.07.1983)
420     automatic transmission, floor shift (с 01.01.1963)
430     headrests in the rear (с 01.01.1977)
440     tempomat (cruise control) (с 01.09.1975)
531     automatic antenna (с 01.01.1963)
570     folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
583     electric window lifters (front doors) (с 01.04.1970)
591     heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
620     emission control system
vehicles with catalyst technique (с 01.03.1985)
731     wood trim, burred walnut root (с 01.08.1980)
812     rear-mounted loudspeaker (с 01.11.1974)
873     seat heater for left and right front seats (с 01.02.1984)
Toona suvel sai otse omaniku käest kuuldud, et tal Mercedes-Benz pakkuda. Kuna tal masin ei liikunud, nägi ta mu "sigarit" ja armus sellesse. Raha tal polnud, seega pakkus ta ise välja vahetusvariandi. Olin koheselt nõus. Kuna Mercedes-Benz ei sõitnud, vedasime nööri otsas masina koju. Esimese asjana, nagu ikka, pidi masinat tööle proovima. Korraks nagu lubas, läks käimagi, siis jälle suri välja. Esmane diagnoos oli kütusesüsteem - auto alt ma end leidsingi. Pisut näppimist ja viga üles leitud - kütusepumpadel (jah neid oli kaks, see oli minisugune mersuinseneride tark mõte teha tandempumbad) juhtmed lahti. Kord oli ühendus, teine kord jällegi polnud. Juhtmed korralikult kinnitatud ja sai esimest korda ridakuue võimsat möiret kuulatud.
Mercedes-Benz haises seest, oli porine (lapsed olla roninud mööda autot ringi, sest see seisis hoovi peal rohkem iluasjana), aga nüüd vähemalt sõitis. Seda rõõmu ei jätkunud kauaks, sest paar päeva hiljem tuli ikka masina jõudusid ka proovida - mõtlesin tänava peal pisut loomi valla lasta. Sõitsin ringi tänaval, spidomeetril sai ka kolmekohalisi numbreid nähtud. Ühel hetkel avastasin end üle 10cm astangu sõitmast (uue asfalti lõpp, vana algus). Pärast maandumist tundsin end kui see vend, kes lennukiga Ülemistesse maandus - midagi oli valesti. Autol kadus jõud ära ja midagi justkui lohises. Autost välja tuldud, nägin "Kutsuge Cobra 11" seriaalist tuttavaid kaadreid - bensiinijuga auto taga. Õnneks oli kõrvaline tee, keset teed seisev auto ei seganud kedagi. Autol olid bensiinipumbad eelmise omaniku poolt pallinööriga auto alla seotud ning nüüd oli see nöör järgi andnud ja pumbad koos filtri ja ??klapiga vastu maad lennanud. Loomulikult läks ühe pumba alumiiniumtoru katki ja mahlad olid väljas nagu kevadel kasest. Praegu mõtlen, et kuradi hea et ühtegi sädet ei tekkinud - auto oleks kindlasti maha põlenud. Paagis oli kütet vähe - selle lasin sinnasamma välja, pärast seda vedasin auto koju hoovi peale. Pisut investigeerimist ja kahjude suuruse kindlaksmääramist. Jõudsin otsusele, et kahjud olid suured. Sinna ta seisma jäigi - tol hetkel polnud pumpa kuskilt võtta ja oli veidi vaja aega atra seada ja järele mõelda. Seisma jäi ta kuuks - kaheks, siis mõtlesin taaskord pisut käsi külge lüüa. Otsustasin, et pean haisust lahti saama ja interjööri lahti kakkuma. Juhiistme ja tagumised istmed sain välja ning siis kadus jälle isu ära. Auto jäi ühe tungraua peale (õnneks toestasin esiosa ära) terveks talveks seisma.
Eelmine nädal otsustasin, et peab ikka vanahärra liikuma panema. Sain siit foorumist kuulutuse läbi pumbasüsteemi (küll ainult ühe pumbaga), viskasin natukene torustikku ümber ja pump oli valmis.
[Pilt: 10032010072.jpg]
Nüüd läks alla ühe-pumba-komplekt, mis hiljem ka tööle hakkas. Tagasi eelmisesse nädalasse - pump tööle ei hakanud, sinna ei jõudnud voolu peale. Kiire foorumituur ja sain teada, et pumba relee võib vigane olla. Kiirelt relee maha, laiali lammutatud ja taaskord viga avastatud. Mingil põhjusel oli trükkplaadil üks rada läbi põlenud.
[Pilt: 13032010084.jpg]
Tinutusega asi parandatud ja nüüd surises pump väga toredasti. Masin ei läinud IKKA VEEL käima. Seekord ei saanud viga küttes olla, seega hakkasime isaga elektrisüsteemi uurima. Süütepoolilt jõudis vool jagajasse, kuid küünaldeni särtsu ei jõudnud. Foorumituurilt tagasi tulnud, käis korraks peast läbi kahtluseuss, et nonii, nüüd on kommutaator läbi. Kiirelt sai siiski ümber mõeldud ja elektri kohalejõudmine jagajasse välistas selle. Jõudsime otsusele, et jagaja kaane all on midagi valesti. Kaane mahavõtmine oli paras jura, alumisele poldile pääses vaid trikkidega ligi. Lõpuks saime kaane siiski maha ja vaatepilt oli huvitav. Teadatuntud asi - kaane all on kõige suurem vaenlane niiskus ja oksüdatsioon. Minul oli mõlemat. Kaanel olid sõna otseses mõttes veepiisad ja silindripulgad olid väga võimsalt oksüdatsioonikihiga kaetud, ka rootor polnud paremas seisus.
[Pilt: 13032010088.jpg]
[Pilt: 13032010089.jpg]
Korralik puhastus ja kuivatus kõikidele detailidele ja kokkupanek võis alata. Komplekteerus auto veidi lihtsamalt, kui lahti tuli, aga kokku ma ta sain. Nüüd sain siis üle pika aja võimsat 2.6 liitrit kuulata. See oli hea hääl!!
Paar pilti tollest päevast siis veel:
[Pilt: 14032010092.jpg]
[Pilt: 14032010091.jpg]
See nädal asusin taaskord Mercedes-Benz kallale. Masinast tuleb sõiduloom teha, seega tuli täielikult kõrvaldada hais ning üldse masinat pisut paremasse olukorda putitada. Kohe sai taha pandud paremad rehvid, et ta ennast üldse kohalt minema suudaks liigutada. Rattad käisid küll ringi ja appi tuli võtta ka audi, kuid kohalt ma temaga ära sain. Natukene ümberplaneerimist ja sai auto parema läbikäidavusega kohta paigutatud. Kiskusin interjööri täielikult välja, kõik istmed ja põhjamatt on väljas. Juhimatt kaalus u 6kg - järjekordne mersuinseneride tark mõte panna svamm mati alla. Nüüdseks oli see siis täielikult vett täis ja ära jäätunud. Sealt alt see hallitus- ja koppehais tuligi. Kuna põhi paljas, tegin ka sellele kuivatuse. Praegu on kogu sisu saunas ja kuivab edukalt. Kui hästi läheb, viskan homme sisu tagasi sisse.
Minu kätte jõudis auto puldist keskluku ja signalisatsiooniga, lisaks oli veel immo. Ka autotelefon oli sees. Kuna tundus, et asjad olid soss-seppade poolt paigaldatud ja ma tahan autot originaalilähedasena hoida, kiskusin kõik kolm komponenti maha. (Signa peksis segast, autoraadio ei töödanud. Immo oli ainuke, mis töötas, aga see tundus väga lihtsalt kõrvaldatav). Seoses sellega on pakkuda mõne õlle raha eest SIEMENSI-BMW autotelefon (miski peaaju, kaardilugeja, ekraan numbritega, telefonitoru ja juhtmestik) ja signasüsteem koos immoga.
Sain kupatuse autost korralikult maha võetud - nüüd on ka endal kindlam tunne, et pole enam nii palju mõttetuid osasid, mis võiksid katki minna ja mind tee peale jätta.
Autost ka veidikene:
Automaatkast töötab hästi, kickdown ka suurepäraselt. Tempomati pole tööle saanud (pole ÜV ega miskit, ei saa suurele teele katsetama minna, kiirust peab 40 vähemalt olema). Jõudu masinal on, roostet ka sama palju. Kuna kerel on suured katted alaääres, on seal all üks suur rooste. Klassikalised esitiivad roostetavad ning karpide kohta ei oska öelda. Tagatulede ümbrus on kahtlane ja ka tagaluuk tahab tegemist. Antenniauk on 2x suurem kui ta enne oli ja kapott on teist värvi. Plaan on eeltöö ise teha ja siis auto klaasidest allapoole värvimisse saata.
Kesklukk justkui töötab, uksed käivad pisut halvasti lahti-kinni. Juhiuksest saab uksi lahti keerata, kõrvalistuja lukust saab uksi kinni keerata. (Selle võtan esimesena ette) Mootor on pisut õline. Tulede korrektor ei tööta.
Plaanis on auto liikuma saada ja siis peaaegu kõik mahlad ära vahetada.
Kas keegi oskab öelda, miks välistemperatuuri andur -35 näitab ? Smile
[Pilt: P3201767.JPG]
[Pilt: P3201766.JPG]
[Pilt: P3201765.JPG]
[Pilt: P3211773.JPG]
[Pilt: P3211768.JPG]
[Pilt: P3211770.JPG]
[Pilt: P3211771.JPG]
Äkki keegi viitsib mulle välja kirjutada, mis mootoriõli, käigukastiõli, hüdraulikaõli ma peaksin suksus kasutama. Hinnaklass võiks olla selline keskmine. Kõige odavamat ei taha aga kõige kallima peale ka hammas ei hakka.
Aitäh.
Ei suutnud vastu panna tänasele lörtsisele ilmale ja läksin tagasilla mõnusid nautima. Jätkuvalt ja üha rohkem on Mercedes-Benz mu lemmikauto.
Märkasin ka paari viga - hoiatustuled põlevad ja seetõttu näeb armatuur välja nagu juudi kuusepuu ja kojamees töötab vaid sel hetkel, kui lülitada see kolmandalt astmelt teisele (ja siis ka ainult üks täispööre).
Jätkuvalt võiks keegi mulle õlide kohta vastust anda.
Mootorisse poolsünti, ise kasutasin BP õlisid, samas vb tasuks esmalt investida rohkem mujale kui kallist õli osta. Pane mingid konkreetsed asjad kirja, mis on prioriteetsemad ja hakka nendest pihtaSmirk
välistemp andur on õhtal kui -35 näitab.
Kurjajuur
To do list:
mootoriõli + filter
käigukastiõli
hüdraulikaõli (=roolivõimuõli ???)
tagasilla õli
tosool
piduriklotsid
välistemp. andur
kohamehelüliti
laadimine
veljed + rehvid
keretööd
istmed korda
mootor puhtaks väljast + plokikaane- ja klapikambrikaanetihend
audio
hetkel siis suvalises järjekorras asjad, mis teha tuleks. Esimene pool tuleks juba puhtalt selle pärast ära vahetada, et armatuuris põlevad põhimõtteliselt kõik tuled, mis nende kohta märku annavad (piduriklotsid, jahutusvedelik, mootoriõli, ASD jne...)
Brick Mercedes-Benz CL500, 2008, c216 - Nnes Nnes 8 1,052 08-11-2026, 04:44 PM
  Mercedes-Benz 200 TD, 1988, S124 – Lexuz Lexuz 23 3,902 18-10-2026, 11:10 AM
Photo Mercedes-Benz S65 AMG 2007 W221 Auto müüdud,teema kinni! cico 8 2,170 06-04-2026, 08:54 PM
  MB 300CE C124/300E ja 230E W124, sm. pelle sm. pelle 301 338,148 01-12-2025, 01:53 PM
  Mercedes-Benz S124 2.5d 1991-Sten Sten-M.M. 12 2,732 01-12-2025, 08:05 AM
  Mercedes-Benz 300 E, 1989, w124 - OnkelMats OnkelMats 49 48,581 01-07-2025, 07:51 AM
  Mercedes-Benz E270 ,2001, w210 - 002 002 1 798 04-03-2025, 09:27 PM
  Mercedes-Benz 200D, 1988, w124 - kodutu kodutu 80 103,372 07-02-2025, 07:55 PM
Photo Mercedes-Benz E270CDi, 2000, w210 - W202 W202 5 1,964 19-01-2025, 08:02 PM
Brick W124, 250D, 1991 - Manifesto Manifesto 22 6,698 24-09-2024, 10:20 PM
