S 320 2004a B servic saab täis 300 000 km
armatuuril teade et 600km pärast B servic on kellegil aimu mis see endast kujutab läbi sõit siis kohe 300 000 km kui peab servicesse minema.kas sel B servisel konkreetsed asjad umbes mis kuuluvad tegemisele?ja kui kulukas see olla võib?tänan kes vastavad kuna naisterahvas siis suht tundmatu kõik see olukord.osad räägivad et hakatakse siis igasugu rullikuid rihmasi jne vahetama aa see pidi väga kallis olema.praegusel ajal pole see üldse hea uudis.et kes käinud mis tehtud ja kes teab mis see B tähendab aitähh!!
A SERVICE (~ $205.95 + tax) :
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE (~ $379.95 + tax) :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
vabandan vaatasin algul et panin teema valesse kohta.nii pikk nimekiri seega võib see hind ka ikka kole kopsakas tulla sealt jah,aga on võimalus õelda et tehke hädavajalik ära nad kippuvad kindalsti esinduses kõike kohe vahetama et aga rohkem pappi saada
Rakvere silberis on praegu tunnihinne 30 % odavam ja varuosad samuti - mine sinna kui Silberisse lähed!
Teine asi - kui auto on käinud varem Silberis hooldusel, siis sa saad lasta küsida, et mis osad lähevad vahetusse. Näiteks mõningatel detailidel on nõue a´la 30 000 km või 2 aastat - kumb enne täis saab siis seda ka tehakse. Arvutist vadatakse ja mingi pildi saab ette. Ehk erinevatel autodel võidakse 300 000 tuhande hoolduses erinevaid asju vahetada ja foorumist ei saa sulle öelda mis sinu autot täpselt ees ootab. Ma ei tea kas suutsin ennast selgelt väljendada?
Ja isegi kui auto on näiteks kogu aeg Silberis käinud ka siis ei saa niiöelda paberite põhjal kõike öelda - sõltub seisukorrast. Paljud detailid kuuluvad niiöelda vaatluse alla ja töömees otsustab kas on vaja vahetada või mitte.
Kui auto ei ole Silberis üldse hoolduses käinud, siis midagi saab muidugi ette ennustada, aga see on tänamatu tegevus. Võimalus on sul lasta niiöelda ülevaatus teha ja nimekiri küsida mis vajab uuendamist.
Keegi ei keela sul ka neid asju seejärel kuskil mujal vahetada või enda varuosadega (ka ÕLI) hiljem silberisse minna.
Aga ühesõnaga Rakvere on märgusõna ja tea et sa oled klient ja sina ütled kas vahetatakse või mitte. ÄRA LASE ENDALE PÄHE ISTUDA.
Aitähh!
  W221 S 320 roolivõim Asjataja 6 969 06-06-2025, 08:53 AM
Viimane postitus: Asjataja
  S 300 SE 126 91a Hervin 5 875 23-01-2024, 10:02 PM
Viimane postitus: Hervin
  W221,320,2008a elektrikala S3pp 1 1,281 13-06-2023, 12:50 PM
Viimane postitus: S3pp
  Mercedes-Benz S 300 3.0 Turbodiesel om606 130kW cohiba 0 735 04-04-2023, 04:41 AM
Viimane postitus: cohiba
  W220 S500 2004a abc vedrustusega vajub üks amort ära s500w220 16 4,297 18-11-2021, 09:15 PM
Viimane postitus: s500w220
  W220 S500 2004a probleem softclosega s500w220 13 3,304 23-09-2021, 10:18 AM
  MB,w221,320,2008a. raadioplokk S3pp 23 8,821 16-03-2021, 09:05 AM
  Lennart Meri S 300 Telepoiss 42 35,821 06-11-2020, 12:33 PM
  W221, S 320 CDI piitre 1 2,202 19-10-2020, 10:22 AM
  W221 350cdi kett läks puruks! Mis nüüd saab? Maakas123 48 31,208 30-03-2017, 07:27 PM
Viimane postitus: Maakas123
