18-09-2011, 07:51 PM
VIN: WDB4633331X124501 dekodeering (soov. inglise-keelne)?
Kirjuta, küsida võib kõike!
18-09-2011, 08:14 PM
(18-09-2011, 07:51 PM)nostromo Kirjutas: VIN: WDB4633331X124501 dekodeering (soov. inglise-keelne)? Название val fin vin WDB4633331X124501 whc WDB chassbm 463333 chass_ident 1X124501 type 463 subbm1 333 subbm2 auxiliary_drive body 463831 10 body_code 3 delivery_date 010216 engine 628962 40 004386 front_axle1 730306 1R 115359 front_axle2 heater interior lights model_idx 1 odometer order_num1 6023500504 paint1 6891 paint2 paint3 paint4 paint5 platform production_num1 6126044 production_order_ref rear_axle1 741144 1R 115548 rear_axle2 release_date 010214 retarder rims service_num steering 765503 10 N01022 trailer transfer_case 750654 00 021132 transmission 722638 02 700497 vin_dc vinwhc winch wiper Code Текст ^^^ Unknown C75 LOWER BODY PROTECTION C77 RADIATOR GRILLE WITH CHROME EFFECT C78 2 STAINLESS STEEL DOOR SILL MOLDINGS, ILLUMINATED D27 ELECTRIC SLIDING/LIFTING ROOF EL1 Unknown EM9 TV TUNER WITH ANTENNA AMPLIFIER ET4 Unknown ET7 Unknown GE9 AUTOMATIC TRANSMISSION WITH SHIFT LOCK H10 HEATER F. DRIVER AND FRONT PASS. SEAT H11 HEATER FOR REAR BENCH SEAT H12 Unknown IX1 Unknown I86 Unknown J44 ULTRASOUND BACKUP ASSIST MR7 Unknown P48 REAR MUD FLAPS Q55 TRAILER HITCH, REINFORCED BALL HEAD, LOW D 96/4 RB9 SPARE WHEEL COVER, STAINLESS STEEL RL8 18" LIGHT ALLOY WHEELS SM7 MULTICONTOUR SEAT, DRIVER T84 SIDE-MOUNTED STEP U46 LEATHER INTERIOR EQUIPMENT VL1 STEER. WH. + SEL. LEV. IN LEATHER/BURL WOOD VERS. VL2 VELOUR FLOOR MATS VL3 EXCLUSIVE PACKAGE VL4 RUBBER MAT FOR LOAD COMPARTMENT V18 INTERIOR TRIM IN BLACK V56 WOOD TRIM BURRED WALNUT ROOT W70 Unknown XU1 GERMAN LABELS / PRINTED MATERIAL XY0 Unknown X02 MODEL BADGE FOR SPECIFIC COUNTRY X30 VEHICLE REGISTRATION BOOK YF4 CD-ROM FOR AUTO PILOT SYSTEM, GERMANY YF9 GARAGE DOOR OPENER INTEGRATED INTO INSIDE MIRROR 6891 Unknown Название Value AF1SV C006015062 AF2SV ENGSV CASESV C011503289 AR1SV C004015071 AR2SV TRANSSV MTRSAC
19-09-2011, 12:36 PM
kas ka minu VINile leiab asjalikuma vastuse? Netist midagi nii põhjalikku pole näinud? WDB1240511B213993
Tänud ette
19-09-2011, 04:49 PM
(19-09-2011, 12:36 PM)põhh Kirjutas: kas ka minu VINile leiab asjalikuma vastuse? Netist midagi nii põhjalikku pole näinud? WDB1240511B213993 EPC Identification number: WDB1240511B213993 6 Chassis Sales designation: 300 CE-24 Order number: 0 - 229 12608 Datacard Paint code 1: 199 APPLICATION CODE FOR COMPONENT PROCESSING Equipment: 261 No code designation available Engine no.: 104980 12 008076 Transmission: 722359 03 360956 SA code 199 APPLICATION CODE FOR COMPONENT PROCESSING 211 AUTOMATIC LIMITED SLIP DIFFERENTIAL (ASD) 221 LEFT FRONT SEAT, ELECTRICALLY ADJUSTABLE 240 OUTSIDE TEMPERATURE INDICATOR 261A LEATHER BLACK 300 - 20101110 - COLLISION MINIMIZATION BRAKE INTERV./WARNING (CMS) 300 - 19880501 - STORAGE BOX IN FRONT TRAY 412 - 19951002 - ELECTRIC SLIDING ROOF 412 - 19980716 - ELECTRIC SLIDING ROOF WITH TILTING DEVICE 420 AUTOMATIC TRANSMISSION 4-GEAR 430 HEADREST IN THE REAR, LEFT AND RIGHT 444 No code designation available 511 RADIO MB EXQUISIT WITH VK,RDS (PANASONIC) 531 AUTOMATIC ANTENNA 543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE- 570 FOLDING ARMREST, FRONT 580 AIR CONDITIONING 600 HEADLAMPS - CLEANING EQUIPMENT 620 AIR POLLUTION CONTROL 812 - 20100219 - BLU-RAY PLAYER 812 - 19951002 - REAR-MOUNTED LOUDSPEAKER 873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS Venelaste leht fin vin WDB1240511B213993 whc WDB chassbm 124051 chass_ident 1B213993 type 124 subbm1 051 subbm2 auxiliary_drive body 01526 body_code delivery_date engine 104980 12 008076 front_axle1 front_axle2 heater interior 261 lights HELLA model_idx 1 odometer order_num1 0-22912608 paint1 199 paint2 paint3 paint4 paint5 platform production_num1 production_order_ref rear_axle1 rear_axle2 release_date retarder rims service_num steering trailer transfer_case transmission 722359 03 360956 vin_dc vinwhc winch wiper BOSCH 900308 Code Текст 211 AUTOMATIC LIMITED SLIP DIFFERENTIAL (ASD) 221 LEFT FRONT SEAT, ELECTRICALLY ADJUSTABLE 240 OUTSIDE TEMPERATURE INDICATOR 300 Unknown 412 Unknown 420 AUTOMATIC TRANSMISSION 4-GEAR 430 HEADREST IN THE REAR, LEFT AND RIGHT 444 Unknown 511 RADIO MB EXQUISIT WITH VK,RDS (PANASONIC) 531 AUTOMATIC ANTENNA 543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE- 570 FOLDING ARMREST, FRONT 580 AIR CONDITIONING 600 HEADLAMPS - CLEANING EQUIPMENT 620 AIR POLLUTION CONTROL 812 Unknown 199 APPLICATION CODE FOR COMPONENT PROCESSING 261 TYPE DESIGNATION ON FENDER / SIDEWARD DELETION VIN koodi järgi saab infot järgnevalt:
20-09-2011, 04:31 PM
Suured tänud, Toomaz!
Kuna otsing mulle midagi huvitavat akude kohta ei rääkinud, siis kas keegi oskab soovitada akut, mis meeldiks 300ce-24'le kõige rohkem? Käivitusvoolu poolest nimelt, mahutavus ja tootja selguvad arvatavasti juba poes.
20-09-2011, 05:03 PM
Poes leitakse kataloogist sinu autole sobivate näitajatega aku, tootjafirma valid rahakoti järgi.
20-09-2011, 07:28 PM
Millise tootja esiamorte W123'le eelistada?
21-09-2011, 08:19 PM
kuidas kütusepumpa peale keerata, et sa saaks rohekm kütust? kas seda polti lahtipoole või kinnipoole ? 3.0D om603
22-09-2011, 08:37 AM
(20-09-2011, 04:31 PM)põhh Kirjutas: Suured tänud, Toomaz! WTF? Mis ajast lahustipõletajale tõsist käivitusvoolu vaja on? Aku osta nii suur, kui alusele mahub ja nii uue tehnoloogiaga, kui rahakott kannatab. AGM oleks muidugi parim, kuid mingit sisulist vajadust selle järele ei ole. Mina võtaks akupoe pakkumistest sobiva Ca (või suisa hõbeaku, kui raha jagub). ![]() Mingist 500 A peaks nagu piisama selle mootorikese käimavedamiseks. Ja see peaks igast enesest lugupidavast akust tänapäeval ka leiduma. Tõsi, ma pean silmas CCA numbrit ja mitte seda kõige suuremat aku kleepsult...
22-09-2011, 10:29 AM
26-09-2011, 09:38 AM
Millise tootja juhet ma peaks siia otsima? Teine variant, milline ots mida juhib(+ / -), saab ise äkki uue meisterdada. Külmad ajad tulemas
26-09-2011, 09:57 AM
(26-09-2011, 09:38 AM)2015c Kirjutas: Millise tootja juhet ma peaks siia otsima? Kas kaanel kirja ei ole? Defa ja Calix on sellised pisikesed. Vahelduvvoolul ei ole vahet, kumb ülemistest on kumb soon, alumine on kaitsemaa. Aga ma tungivalt soovitan iseleiutamisest loobuda - üsna kerge on kedagi ära tappa niimoodi.
26-09-2011, 10:19 AM
Kuskil pole midagi kirjas. Juhe tuleb siit eest sisse ja siis läheb kaheks, üks mootoriblokki ja teine salongi kus tavaline toa 220v, pistik, puhuri jaoks.
26-09-2011, 01:03 PM
Ehk pöördud mõne firma poole, kes analoogseid seadmeid paigaldavad, ilmselt saad neilt ka vajaliku kaabli.
27-09-2011, 07:46 PM
Tere. Meil töö juures kummitab mitu aastat küsimus, kes on Ott Leplandi isa.
27-09-2011, 09:00 PM
(27-09-2011, 07:46 PM)John Smith Kirjutas: Tere. Meil töö juures kummitab mitu aastat küsimus, kes on Ott Leplandi isa. Isadega on keeruline, seda vahel ei te emagi 100% täpsusega, kuigi tema vähemalt aimab...
02-10-2011, 10:27 PM
Oskab ehk keegi nõu jagada.
Mis järjekorras peaks w201-l plokikaane polte kinni keerama?
The best or nothing
03-10-2011, 07:28 AM
(02-10-2011, 10:27 PM)sten130 Kirjutas: Oskab ehk keegi nõu jagada.esiosa 8 4 2 6 10 tagaosa 7 3 1 5 9
03-10-2011, 09:24 PM
Tänud
The best or nothing
03-10-2011, 09:35 PM
(Seda postitust muudeti viimati: 03-10-2011, 09:43 PM ja muutjaks oli hannes_s.)
Juba mõnda aega plaanis soetada jõuvõti/dünamomeeter/newtonmeter millel skaala kuskil 0-70Nm.
Oskab keegi neist midagi rääkida, millist kindlasti mitte osta jne. Silma jäi üks selline pakkumine http://www.auto24.ee/products/detail_pro...?id=452517 |
| Võib kustudada! | Minister | 0 | 902 |
| Naisperele kõike paremat naistepäevaks! | Heinar | 18 | 20,545 |
| Palju võib maksta?... | kpokyc | 0 | 3,822 |
| Palju võib maksta rumulast nahkistmed C klassile (W202) ? | Scratch | 8 | 10,539 |
Kuidas õnn võib uksele koputada. | kuld | 27 | 25,379 |
