Kahtlane sisu/salong Vito bussis (Leedu)
Buss ise näed viisakas välja ja see sisu kohe nagu kutsub ostma. Pildilt tunduvad nagu oleks express või savanna istmed sisse poogitud või on MB-l facelift vianol ka selline salong olemas?
Muidugi märksõna Leedu, ega midagi muud seal pole Eusa_angel
[Pilt: mercedes-benz-vito-2-2-l-mpv-minivan-200...34525.html]
http://en.autoplius.lt/ads/mercedes-benz...34525.html
Main data
Parameter Value
Ident. number (FIN) WDF63970313303036
VIN WDF63970313303036
Baumuster 639703
Sales name 111KB/ L4X2 3200
Permanent link http://carinfo.kiev.ua/cars/vin/mercedes...su=x8lf3jb
Order number 5 6 555 19399 (Destination: Norway)
Delivery date 20 12 2006
PAINT1 9154 PAINT COLOR, CHARCOAL BLACK METALLIC MB 9154
Interior color 1332 No code designation available
Engine 646980 51 296934
Gearbox 722682 06 772878
General data for model code 639703
SA codes
Parameter Value
423 No code designation available
555L NORWAY
926 No code designation available
AC7 AXLE RATIO I = 3.273
BB3 ELECTRONIC STABILITY PROGRAM (ESP)
E57 ELECTRICS FOR TRAILER-COUPLING SOCKET
ED5 PARAMETERIZABLE SPECIAL MODULE
EE8 12V BATTERY 100 AH
EL9 2-WAY SPEAKER AT FRONT AND REAR
EN0 RADIO SOUND 5
ES1 12 V SOCKET PASSENGER COMPARTMENT
F61 INSIDE REARVIEW MIRROR
F66 LOCKABLE GLOVE COMPARTMENT
F68 HEATED AND ELECTRICALLY ADJUSTABLE OUTSIDE MIRROR
FS5 ILLUMINATED MIRRORS FOR SUN VISORS
FZ8 CONVENIENCE OPENING/CLOSING W. INFRARED REM.CONTRL
G40 AUTOMATIC TRANSMISSION
H00 HOT/COLD AIR DUCT TO PASSENGER COMP.
H12 HOT WATER ADDITIONAL HEATER
H13 ADDITIONAL HEAT EXCHANGER, REAR
H16 SEAT HEATER FOR DRIVER
H20 HEAT-ABSORBING GLASS ALL ROUND
HF2 POLLEN FILTER
HI1 CLIMATE ZONE 1 (COLD/COMFORT)
HY1 RADIO REMOTE CONTROL FOR AUXILIARY WATER HEATER
HZ0 ELECTRIC HEATER BOOSTER
IL2 EXPORT CODE
J65 OUTSIDE TEMPERATURE INDICATOR
JA1 INDICATOR LAMP FOR WIPER FLUID LEVEL
JC1 COCKPIT STANDARD
L04 AUTOMATIC DIM-DIP LIGHT
LD9 INTERIOR LAMP(S) IN REAR
M49 ALTERNATOR 14 V / 180 A
MF4 LOW-EMISSION VEHICLE EURO 4 GR. III
MP2 ENGINE OM 646 DE 22 LA 85 KW (116 HP) 3800 RPM
RF8 TIRE MANUFACTURER MICHELIN (80)
RG1 TIRES 205/65 R16
RR6 SPARE WHEEL WITH JACK
RS3 6.5 J X 16 STEEL WHEELS
SA6 CO-DRIVER'S AIR BAG
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
T70 CHILD SAFETY LOCK ON DOORS IN PASS. COMP.
UR3 REAR SEAT MOUNT W/ QUICK FASTENER; 2 SEAT ROWS
US2 3-PASS. BENCH SEAT, 2ND ROW W/ FOLDING OUTER SEAT
V23 INTERIOR TRIM, UPGRADED VERSION
V36 HEADLINER
V41 PLASTIC FLOOR TPO IN PASSENGER COMPARTMENT
VA6 FULL SIDE WALL PANELING
VH1 GRAB HANDLES IN REAR
VT0 MATEO ANTHRACITE FABRIC
W16 LEFT FRONT WINDOW, FIXED IN SIDE WALL/SLIDING DOOR
W17 RIGHT FRONT WINDOW,FIXED IN SIDE WALL/SLIDING DOOR
W49 MANUAL VENT WINDOW, PASSENGER COMP. REAR
W65 TAILGATE
W70 COLOR GLAZING IN REAR, BLACK GLASS
W78 LIFTGATE/REAR-END DOOR WINDOW W/ WIPER+WASHER SYS.
X48 PLATES / PRINTED MATERIALS DANISH
XA2 WEIGHT VERSION 2940 KG
Y10 FIRST AID BAG
Y44 HAZARD WARNING TRIANGLE
YE5 ASH TRAY AND DRINKS HOLDER IN PASS. COMP.
Z42 APPROVAL AS PASSENGER CAR
ZK5 STATION WAGON
SA numbers
Parameter Value
01 522600/02 522601/06 522602/03 522603/04 522604/10 522605/08 522611/10 522616/11 522634/03 522636/10 522638/01 522639/01 522642/03 522644/01 522645/03 522674/01
03 522606/03 522607/03 522608/06 522609/10 522634/03 522640/05 522641/01 522650/03 522651/07 522651/14
05 522605/08 522610/03 522619/02 522624/02 522629/02 522639/01 522642/03
07 522612/03 522613/03 522614/12 522617/03 522647/16 522651/07 522651/14
09 522615/23 522617/03
13 522618/03
14 522613/03 522617/03 522620/03 522630/06 522630/13 522673/05
15 522603/04 522605/08 522630/06 522630/13 522649/34 522673/05
18 522623/03 522625/03 522626/01 522627/02 522629/02 522639/01
20 522617/03 522628/02 522632/02 522636/10 522661/07 522672/03
22 522614/12 522643/03 522667/03
54 522649/34
Other information
Parameter Value
Body 3
Additional info for engine
Parameter Value
AGG_VAR A 646 010 32 97
ETV_BM 64698050
ZUTEXT
Variant A 646 010 32 97
Number for spare parts 64698050
Text BITTE DIESE TEILENUMMER BESTELLEN
Istmete ja sisu pärast maksta pea 2x rohkem. Selle hinna eest saaks juba järgmise põlvkonna Vito. Eks valiku teeb muidugi ostja.
Pdr Eesti OÜ
Autotöökoda
Narva mnt.150A
55996236
Helari pakutud link https://itais.vta.lt/itais/services/sear...ution=e4s1 sellise nr ja VIN-ga autot ei leia ...
kahltlaselt väga odava hinnaga . vist mootori või kasti probleemiga
Priit, see teine lahter seal päringus on registreerimistunnistuse nr, mitte sõiduki registreerimisnumber. Otsi ainult VIN-koodiga, siis toimib ka sel Vitol.
Aitäh! Peab ikka tõlkima, mitte eeldama, mis lahtri sisu võiks olla Smile
(21-02-2017, 03:06 PM)Helari Kirjutas: Priit, see teine lahter seal päringus on registreerimistunnistuse nr, mitte sõiduki registreerimisnumber. Otsi ainult VIN-koodiga, siis toimib ka sel Vitol.
(21-02-2017, 03:01 PM)arturmalcik Kirjutas: kahltlaselt väga odava hinnaga . vist mootori või kasti probleemiga
Huvitav kust otsast see odav on. Auto on 2007, tegelikult 2006 aasta lõpp. Sellise hinnaga saab juba 2010 aasta nahksisuga bussi. jah vinge, eriline nahksisu ja välimus ka ok. Aga selle pärast rohkem maksta. Ma ostan siis juba 2010 aasta auto tavalise nahksisuga. Aastast 2008 leidsin mitu Vitot hinnaga 8500-8900 eur ja olid ka nahksisudega. Ja me räägime siin Leedu või Saksa turust. Eestis on müügil üks Silberi ajalooga Vito aastast 2008 ja hind 13 900.
Pdr Eesti OÜ
Autotöökoda
Narva mnt.150A
55996236
Hind on natuke krõbe aga ega ostma teda ei jookse hetkel, jäi silma oma erilise salongi poolest. Pole Vianos ja Vitos selliseid istmeid varem näinud, rohkem kohanud USA busside sees taolise tegumoega salongi.
Tulevikus ehk tõesti MB buss kui pere peaks suurenema aga siis ikkagi juba facelift mudel ja võimsama mootoriga.
  VITO(w639) 109 CDI - laadimise tuli põleb, salongi taustavalgus kustub IUrmoI 8 1,150 10-03-2024, 07:42 AM
  2014 Vito diisel pihustid ei toimi KKk 4 743 05-02-2024, 11:37 PM
  Vito ei käivitu külmaga - elektri mure ratsoup 9 1,054 09-01-2024, 07:04 PM
  Vito Tourer 2023 CD-pleier Antz 0 513 16-07-2023, 02:14 AM
Viimane postitus: Antz
  Vito 2003 edasi ei puhu sooja Old_timer 11 1,531 24-01-2023, 11:26 PM
Viimane postitus: jass161
  W639 Vito 115CDI MY2006 - Aku tühi paari päevaga, voolukadu aix6 3 944 24-01-2023, 09:18 PM
Viimane postitus: onu_siim
Video Vito w639 kolks taga Eenmaa 1 568 02-01-2023, 10:48 PM
Viimane postitus: Eenmaa
  MB Vito 2007a kärukonksu juhtmete värvid imre 3 792 08-11-2022, 05:59 PM
  Probleem 1998 MB Vito W638 108D käikudega (manuaal) hbmluiks 3 879 05-11-2022, 01:15 AM
Viimane postitus: Ernst
  2008 Vito tehase webasto Jalmar 1 998 12-12-2021, 08:52 PM
Viimane postitus: isakene
