2008-2015 W204 vabalthingav C63 AMG 6.2 V8 kõige karmima heliga AMG? + IPE väljalase
M156 6.2 V8 32V AMG vabalthingav
336kW / 457hj @ 6800RPM
600Nm @ 5000RPM
0-100: 3.9s
Vähemalt YT videote põhjal tundub nii:
Ja muidugi klassika (ei poolda ametivõimudele vastuhakkamist aga heli lihtsalt SUPER!):
Miks just C63? Kas selle väljalase on laiemate torudega? Meenutab juba peaaegu Chevy Big Blocki-ikka eriti robustne ja brutaalne isegi AMG kohta.
Nagu miski ei hoiaks tagasi kui osadel keremudelitel (eriti S-klassil) on see paraku suuremal või vähemal määral paraku summutatud.
Ning IPE väljalaskega veelgi karmim (+7kW / +30Nm / -25kg täielik komplekt 5000€):
http://www.ipe-f1.com/index.php/en-GB/ex...mgc63-w204
[Pilt: 01-Full-System.jpg]
"C63 AMG (2008–2015)[edit]
The C63 AMG is reportedly the first AMG-Mercedes designed from the ground up. Its AMG C-Class predecessors had essentially featured "bolt on" performance modifications, and according to Car and Driver these earlier AMG models suffered from "relentless understeer" and "heavy steering". The C63 AMG has a revised front end suspension that is taken from the CLK 63 AMG Black Series.
The ESP can now be completely turned off, interfering only under heavy braking.
The C63 AMG also has the quickest, most responsive steering of any Mercedes to date.
AOL Autos described the new C63 as the best driver's car in the Mercedes lineup.
The AMG 6.2L V8 engine, despite being detuned compared to other AMG offerings using the same powerplant, still provides the C63 AMG with more horsepower and torque over direct rivals such as the Audi RS4 and BMW M3.
The 7G-Tronic automatic transmission has AMG SpeedShift with three shift modes – Comfort, Sport and Manual – with the last one running with the converter locked allowing the driver to hold the engine at the rev limit.
Car and Driver tested the car in their December 2007 issue and recorded a 0–60 mph time of 3.9 seconds and a quarter-mile time of 12.3 seconds at 116 mph (187 km/h).
This made the C63 AMG the quickest 4-door production sedan in the world at its debut."
C63 hääl on võimas jah, ma olen neid videosid nädalavahetusehommikutel voodis vedeledes sageli vaadanud. C63 puhul lihtsalt ongi summuti suhteliselt vaba hingamisega võrreldes kõigi teiste M156 mootoriga autodega.
Ma lasin oma ML63'l eesmised resokad ära võtta Jõujaamas, sai ka hääle natuke paremaks. ML'il on see ikka väga maha vaigistatud originaalis, pole peaaegu üldse V8 häält kuulda. Ilma resokateta läks paremaks, aga endiselt on ikka selgelt vaikses otsas. Samas ML ei ole väga paarutamise auto ka. Sellegipoolest kaalun resokad tagasi panna ja tagumised pütid mingite veidi vabamate vastu vahetada.
See IPE tämber mulle ei meeldi eriti. Ja üldse, enamik C63 aftermarket väljalaskeid on üsna vulgaarselt lärmakad ning lasevad terava resonantsi sisse teatud pööretel. See meenutab mulle põlveotsatuuningut, mitte kvaliteetset kõlalaboris ehitatud väljalaset.
Minu meelest selline -> https://www.youtube.com/watch?v=cLRhgz-Yej0 on palju viisakam, ei paugu ja tärise. Saan aru, et stock väljalase, va X-pipe.
MB G63 AMG; MB ML320; Porsche 911 Turbo; Audi Coupe Quattro V8; Volvo 940 SE; ZAZ 965 Cabrio
  Mercedes AMG mootoriõli python 0 474 19-01-2025, 12:13 PM
Viimane postitus: python
  Soovitage head sillastendi töökoda tallinnas AMG jaoks (GLC 63) GLC 2 857 24-07-2024, 07:03 AM
Viimane postitus: indrek
  AMG mersud Eesti registris hents99 104 154,899 24-03-2023, 02:24 PM
Viimane postitus: noosik
  C253 AMG GLC 63 S kiiruspiiraja eemaldamine Joel. 6 5,318 17-08-2020, 09:18 PM
Viimane postitus: Cane
  2008 CL63 AMG M156 (150.000 km) plokikaanepoltide ja piduriketaste + klotside vahetus nostromo 19 14,065 15-12-2019, 05:17 PM
  2008 CL63 M156 plokikaane poltide vahetuse vajadus mootori nr alusel 156984 60 027692 nostromo 3 5,500 11-12-2019, 09:41 PM
  G-klassi AMG-d võimsuse/kronoloogilises järjekorras (G36 AMG/G55 AMG/G63 AMG/G65 AMG) nostromo 3 12,349 03-08-2019, 04:42 AM
  2003 CL55 AMG ABC ölivahetus nostromo 3 8,835 19-02-2017, 02:58 PM
  Cl55 AMG rihmarullikud Ogadik 1 7,418 23-01-2017, 08:46 PM
Viimane postitus: Joel.
  w220 s55 AMG 265kw mootoris vibratsioon ytka29 4 11,471 02-12-2016, 10:59 PM
Viimane postitus: ytka29
