W124 bensuka püsikiiruse hoidja lisamine diisel mootoriga isendile
Kõik on võimalik, aga usu mind, see saab olema väga raske.
Lihtsam on sul osta, kas tutikas vanatüübi püsika mootor või leida korralik selline.
Selle uue püsika mootori aretamine läheb vääääga keeruliseks.
Minu probleemist kirjutab ka see remondiõpetus http://userweb.windwireless.net/~jimc/ma...cruisetest
The next test is done with the key on and the engine definitely not running. Connect one jumper between pins 5 and 3, another between pins 8 and 10, and another between pins 7 and 4. The ohmmeter should be connected between pins 13 and 14. When the Accel switch is activated the measured resistance should decrease smoothly to zero. Moving the switch to Cancel or pressing the brakes should return the resistance to the approximately 3000 ohms value. Repeat this test several times, especially trying to 'tease' it slowly. If the resistance jumps to a large value at any time the actuator itself has suffered internal damage to its feedback potentiometer, usually due to wear. I have heard of this being repaired by painting conductive substances on the damaged resistance track, but I have never done so. Procuring another actuator (used?) may be the best option at this point.
  Kütusepaagi anduri puhastamine (W124) RivoA 21 31,285 28-01-2024, 11:26 PM
Viimane postitus: iseteenjasaan
  w124 200d [u]hõõgküünlad[/u] suvel? melw124 2 1,228 26-08-2023, 08:01 PM
Viimane postitus: melw124
  w124 Kojamehe mootori vahetus RivoA 5 15,765 31-05-2018, 11:18 AM
Viimane postitus: Eero_S
  w124 Klapisääre tihendite vahetamine (M103) MarekV 5 7,682 29-07-2017, 01:27 PM
  Tagumise rattalaagri vahetus (w124) MarekV 5 9,792 07-05-2017, 01:58 AM
Viimane postitus: MarekV
  W140 Sooja mootoriga käivitamise üks murelastest icecube 0 2,118 12-03-2017, 07:41 PM
Viimane postitus: icecube
  W124 e300d 100kw 1995a mootori juhtmed arturmalcik 0 2,792 26-07-2016, 03:51 PM
Viimane postitus: arturmalcik
  W124 püsikiiruse hoidja kerdok 2 4,096 27-04-2016, 06:52 AM
Viimane postitus: dexter
  W124 spidoploki ja keskkonsooli valgustuse kaitsme ja potentsiomeetri remont. Laur 16 35,747 06-03-2016, 06:37 PM
Viimane postitus: janek126
  w140 (92-98) / w210 (96-05/97) / w124 (94-95) ir pultide sünkroniseerimine marek 5 24,564 02-08-2015, 08:47 PM
