E500 w211, 2003, Oliverk
Mark: Mercedes-Benz
Mudel: E500
Varustus:
Avantgarde pakett
Ventileeritavad soojendusega Nappa mustast nahast 2x mäludega istmed
el. reguleeritav roolisammas
16:9 formaadis Command, Harman/Kardon Prologic 7 surround heli
6 CD boks keskkonsoolis (nupule vajutades sõidab üks nuppude paneel eest ära)
NAVI + terve Euroopa kaart Soomest Iirimaa ja Itaaliani. Peatselt ka baltikum.
4-tsooni kliimaseade Climatronic
Airmatic vedrustus (3-4cm kõrgendus, Comfort, Sport 1, Sport 2)
17" Orig veljed Conti SportContact 2 245 laiade rehvidega ees ja taga.
Parkimisabi Parktronic
Nokia 6230i keskkonsoolis
Bi-Xenon tuled
Kurvituled
ca 100 000 erinevat mugavusreziimi, mida saab pardaarvutist seadistada
Delivery date 31.03.03
Dealer Luebeck branch (205)
Interior leather "nappa" anthracite (841)
Paint
197 obsidian black metallic (с 1978)
Options
M50 5L engine
053 aej. 02/2 (с 22.09.1997)
213 parameter steering (с 01.07.1989)
220 parking aid (с 01.10.1993)
242 right front seat electrically adjustable with memory feature. only applicable to series w 210 when installed in conjunction with code 275. (с 01.03.1983)
249 automatically dipping inside rear view mirror (с 01.06.1990)
260 elimination of model designation on rear lid (с 01.05.1968)
275 front seat positioned lower
memory package (driver's seat, steering column, mirror) (с 01.10.1993)
280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
354 antenna on roof centre rear for mobile D-net telephone
antenna on roof centre rear for standard D-net telephone (с 01.10.1994)
382 Unknown code
401 comfort front seats with ventilation and seat heaters (с 01.01.1996)
423 5 speed automatic transmission / nag (с 01.03.1994)
489 Unknown code
500 outside rear view mirror left and right, folding (с 01.10.1993)
527 Reims adapter and paint kit
551 anti-theft/anti-break-in warning system with anti-towing system (с 01.04.1998)
581 automatic climate control (с 01.01.1977)
600 headlamp wiper/washer (с 01.08.1971)
615 lamp unit, asymmetrical l.h. traffic, and front and rear door courtesy lamps
like 610, and with type 107 bifocal bulbs
611 + 613 (с 01.11.1978)
633 Unknown code
673 high-capacity battery (с 01.01.1964)
803 Change of year of model, last figure shows new model year
810 loudspeaker, sound package
sound package (bose) (с 01.12.1986)
819 CD changer - alpine - in trunk (с 31.07.1992)
882 passenger compartment protection/towing-off protection (with anti-theft warning system only) (с 01.07.1993)
884 trunk lid additional locking mechanism (hzs) (с 01.10.1989)
910 14V/65A alternator
alternator with increased capacity (с 01.11.1990)
915 fuel tank, 70 liter (с 01.05.1988)
926 emission control eu4-measure 30.11.1991 (с 09.09.1997)
954 equipment package for avantgarde vehicles (с 01.06.1993)
rotating emergeny flasher, front (red light)
Pildid ja jutt sellest kuidas ja kust sõiduk tuleb
Soovitatav valida "Slideshow" ja panna piltide vahetamise ajaks 6-10sec
väga ilus auto tundub... spidol aint 220? rohkem ei läind vä? Smile
Väga rõõmustav näha, et Oliverk on vahepealsetelt eksirännakutelt jälle õige automargi juurde saabunud ja veel milline kaunitar, ülikõva isend.
kiirteed said otsa. Polnud võimalust rohkemaks. Aga olen 100% kindel, et 250-ne piiraja pole probleem.
Isendi kohta - on tõesti hea isend. Kõik hooldused tehtud esinduses. Midagi kuskilt kulunud ei ole (isegi mitte natukene). Nagu uus auto. Lõhnab ka veel selle järgi.
Karl Kirjutas:... ja veel milline kaunitar, ülikõva isend.
ei ma juba avastasin, et toorik :lol:, keyless go'd ple...
marek Kirjutas:
Viinamarjad hapud? Iccccc....
Karl Kirjutas:Viinamarjad hapud? Iccccc....
muidugi, 1 viga on veel, pole minu oma! :lol:
Mille alusel see info, et Baltikumi kaart tulekul? DX II siis? Oleks see vaid tõsi...
Imre Kala soovitas veidi oodata - tuleb sügisel või hiljemalt järgmise aasta algul. Nagu ma aru sain.
Andres Kirjutas:Imre Kala soovitas veidi oodata - tuleb sügisel või hiljemalt järgmise aasta algul. Nagu ma aru sain.
Päris loogiline, et tulemas, kuna näiteks TomTom 6 Ida-Euroopa kaart on minu arust juba hea (ise sõitnud selle järgi Eestis, Lätis). Ju autofirmad ka lasevad nüüd navisid uuendada.
Et seekord siis talvele vastu ilma 4-maticuta.
Aga jah, luiged veel siin ju.
Gre Kirjutas:Et seekord siis talvele vastu ilma 4-maticuta.
Länkkarimees tuli põrkama 4WD suhtes :bigsmile::lol: Ok, nali.
Enamus sõidab meist siin ühesilla veoga ja ikka toksime klahve foorumis, elus mis elus. Pealegi uuematel autodel aitab elektroonika ka päris palju talvega hakkama saada, kuigi ega 4 veo vastu ei saa miski...
Karl Kirjutas:
Nii, kui noka lahti teed siis kohe :
[Pilt: admin.gif]
Talv tuleb selle autoga huvitav Smile Keal peab olema vastu peatuge muidu võib 1300rpm pealt kogemata nõks läbi käia ja... St parempoolse pedaaliga peab hellalt läbi käima.
Ei ole see asi nii hull ikka ühti, mida uuem ja võimsam auto on, seda rohkem ka elektroonika neid hobuseid pidurdab. Kõige hullemad ongi just siuksed vanad autod, millel mootorit on, aga ASR ist või ASD st pole haisugi, igasugusetest stabiilsuskontrolidest ja muudest asjadest rääkimata.
Indrek Kirjutas:Ei ole see asi nii hull ikka ühti, mida uuem ja võimsam auto on, seda rohkem ka elektroonika neid hobuseid pidurdab. Kõige hullemad ongi just siuksed vanad autod, millel mootorit on, aga ASR ist või ASD st pole haisugi, igasugusetest stabiilsuskontrolidest ja muudest asjadest rääkimata.
Ma väidaks just vastupidist, elektroonika tõmbab kogu jõu maha ja "tavaautod" saavad paremini paigalt minema.
Pidevalt peab "ESP off"-i näppima.
W124 E500 Limited
Seda ma räägingi - jutt oli ju talvel liikumisest ja sellest, et liiga võimas auto on ohtlik - ued võimasd just pole ja on talvel mugavamad ja turvalisemad
Sai siis vahepeal navi update tehtud ja peale läks uus originaal plaat NAVI DVD COMAND APS 7.0 2008 APS COMMAND MERCEDES varuosa nr B67823855
Balti riikidest on kahjuks ainult suurlinnad peal ja neetki halvasti, aga kuna lähimal ajal tulemas üks pikem euroopa turnee siis see on seal ilusti 100% kaetavusega peal.
MB C320CDI
Navi töötab Eestis tänavate ja maja nr järgi, enamus asju leiab üles ka, nagu bensujaamad hotellid, söögikohad jne. Lisasin mõned vaated...
MB C320CDI
Vahepeal jõudis läbisõit 145 000 peale ja tuli Silberit külastada, kus selgus, et tuleb "suur hooldus" teha, mis kokku läks maksma 15 000.-eeki (kõik õlid, filtrid, küünlad 16tkSmile +aastaga olin jagu saanud ühest esisilla ülemisest sarniirist ja turvavöö posti poltstrist, mis tuli uus panna, aga sillaosast oli see ka kõik selleks korraks.
Pool aastat tagasi sai üks tagumine õhk amort ja veel mõned uued esisilla osad alla aga see oli suht väike summa (7800+2500eeki). Võiks öelda, et isegi hästi peab see W211 vastu.
  Mercedes-Benz S500, 2003, W220 - Marksus Marksus 7 668 23-04-2024, 02:40 PM
  W211 E320 - canyondrift canyondrift 35 20,131 01-07-2020, 04:25 PM
Viimane postitus: ignar
  W211, 320 CDI, 2004- Andrjuha84 andrjuha84 12 15,244 03-09-2015, 11:14 AM
Viimane postitus: Black66
  Mercedes-Benz,V220 CDI ambiente,2003 V_666 7 8,846 30-11-2005, 11:27 PM
Viimane postitus: Sulo
