W202 Starting issue
Hello Everyone,
I would like to know if someone could give me some ideas.
I have a W202 C200 1995, the engine cranks but wont start. The engine will only start if you put some fuel in the throttle body, and the car will run with no problems until you shut it down. I have been checking the following things:
Fuel pump - ok
Fuel pressure - 4 Bar
Crankshaft position Sensor - ok
Over voltage relay - ok
Alarm - ok
Immobilizer - ok
Wiring Harness - ok
I have taken the fuel injectors rail out and there is no fuel when cranking.
If you guys have some ideas what else to check please let me know
-Santtu
  w202 bensiinipumba relee dinowalk 4 263 19-11-2023, 07:35 PM
Tongue W202 2.0D 55kw süüteluku juhtmete erinevus Mersuotsingul 0 145 20-10-2023, 03:52 PM
  W202 Diffri erinevus rexrex 4 380 15-02-2023, 04:23 PM
Viimane postitus: rexrex
  w202 mootoriaju pinout 7hp 0 390 05-01-2023, 03:39 PM
Viimane postitus: 7hp
  W202 250td ei puhu jalgadele sooja Alpz 1 574 09-12-2021, 10:11 PM
  W202 c180 rev limiter merce 2 1,047 21-01-2021, 07:09 PM
Viimane postitus: merce
  w202/H0 2.0 D (OM 601),1994a. küsimused Jokker 12 3,069 28-12-2020, 10:40 PM
Viimane postitus: Jokker
  W202 VDO MSE H10 ecu pinout xmediax 0 947 25-12-2020, 05:25 PM
Viimane postitus: xmediax
  w202 250 diisel (OM 605) kaal HarryPokker 2 1,581 23-08-2020, 09:09 PM
Viimane postitus: HarryPokker
  w202 250d jahutustemp. HarryPokker 0 1,218 23-08-2020, 01:43 PM
