  • 1Hääli - 1 keskmine
Laur E 350CDI
Üks mees siin otsustas jälle omale millegipärast Mercedese soetada, see kord siis sedaani.
Valisin varustuse järgi, pidi kindlasti distronicuga olema, ülejäänu olgu mis on.
Sai selline:
Model E 350 CDI 4MATIC
Engine 642856 40 988651
Transmission 722962 02 784156
Order Number 0 0 235 20048
Order Location WUERZBURG BRANCH
Interior LEATHER - BLACK/ANTHRACITE (201A)
Paint 1 OBSIDIAN BLACK (197U)
Release Date 2010-05-20
Delivery Date 2010-05-31
Code Description
030 ELECTR. REGULATED DIESEL FUEL PUMP
050 AEJ 09/2
061 STEUERCODE FUER KRAFTSTOFFPUMPE
108 CONTROL CODE MARKETING
110 FUEL AMOUNT FOR COLLECTION BY CUSTOMER
197U OBSIDIAN BLACK
1P1 CONTROL CODE MARKETING
200A LEATHER
201A LEATHER - BLACK/ANTHRACITE
202B OWNERS MANUAL AND SERVICE RECORD - GERMAN
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING
229L GERMANY
230 PARKING GUIDANCE
233 AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
234 BLIND SPOT ASSISTANT
236 ADAPTIVE REAR INTERIOR LIGHT
23P DRIVING PACKAGE
249 INTERIOR AND EXTERIOR MIRROR,AUTOMATICALLY DIMMING
255B MB MOBILO WITH DSB AND GGD
260B AIRBAGLABEL - GERMAN/ENGLISH
279 ELECTRONIC GEAR RANGE SELECTION
287 THROUGH-LOADING FEATURE
289 LEATHER STEERING WHEEL WITH TRIM INSERT
291 PELVIS AIRBAG (PELVISBAG)
294 KNEE AIRBAG
2XXL FEDERAL REPUBLIC OF GERMANY
302B HEAD UNIT LANGUAGE - GERMAN
332B INSTRUMENT CLUSTER/HU LANGUAGE - GERMAN
386 UNIVERSAL TELEPHONY PACKAGE
401 FRONT SEAT CLIMATE CONTROL
409 FRONT LEFT AND RIGHT MULTICONTOUR SEAT
427 AUTOMATIC TRANSMISSION 7-SPEED
428 STEER.WHEEL GEARSHIFT BUTTONS/SHIFT PADDLE PAINTED
474 DIESEL PARTICULATE FILTER
475 TIRE PRESSURE CONTROL
476 AUTOMATIC LANE RECOGNITION
489 AIRMATIC DUAL CONTROL / AIR SUSPENSION SEMI-ACTIVE
518 UNIVERSAL COMMUNICATIONS INTERFACE (UCI)
527 COMAND DVD APS WITH NAVIGATION
581 AUTOMATIC CLIMATE CONTROL
600 HEADLAMPS - CLEANING EQUIPMENT
608 AUTOMATIC HIGH BEAM SWITCH (IHC)
619 CORNERING ILLUMINATION
622 HEADLAMP WITH ILS, RIGHT-HAND TRAFFIC
670 RESIDUAL ENGINE HEAT UTILIZATION (MRA)
682 FIRE EXTINGUISHER
731 TRIM PIECES - WOOD BURRED WALNUT VENEER
800 CHANGE OF MODEL YEAR, THE LAST FIGURE SHOWING THE NEW MODEL YEAR
875 HEATED SCREEN WASH SYSTEM
915 FUEL TANK WITH GREATER CAPACITY - VOLUME 2
928 EXHAUST GAS CLEANING WITH EURO 5 TECHNOLOGY
955 EQUIPMENT PACKAGE ELEGANCE
967 COC PAPER EURO 5 TECH. W. REGISTRAT .CERT. PART 2
A21 SHIFT BY WIRE
A31 SOFTWARE (INDIVIDUAL)
A36 TORQUE CONVERTER HOUSING AGA
A49 CONVERTER WITH 3 FRICTION DISKS
A52 M - VALVE BODY ASSEMBLY WITH VGS 3
B12 WHEEL REPLACEMENT TOOL
F212 MODEL SERIES 212
FW LIMOUSINE
G962 TRANSMISSION CODE VERSION 62
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
J52 ADDITIONAL CODE FOR DAMPING MAT
K10 SOFTWARE CONTROL FOR STATIC CURVE ILLUMINATION
K11 ADAPTIVE STOP LIGHT FLASHING
K13 CONTROL CODE FOR SERVICE INTERVAL 25000 KM
L LEFT-HAND STEERING
M005 VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M019 SERVICE REPOSITIONED
M30 DISPLACEMENT 3.0 LITER
M642 V6 DIESEL ENGINE OM642
P35 LIGHT PACKAGE (FFO)
P81 DYNAMIC PACKAGE EXTERIOR
R01 SUMMER TIRES
R15 LT ALLOY WHEEL 10 DBL-SPOKE DESIGN 17" ALL-ROUND
U01 REAR BELT STATUS INDICATION
U18 AUTOMATIC CHILD SEAT RECOGNITATION (AKSE)
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
V06 SPEED- + LOADINDEX 95W
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
Muretuid kilomeetreid!
Väga kena
Vaikne rahulik soliidne
Selle mõttes, et on vaiksemaid autosid. Maanteemüra kohati suur meie teedel.
(24-10-2018, 11:31 AM)Oliver.L Kirjutas: Selle mõttes, et on vaiksemaid autosid. Maanteemüra kohati suur meie teedel.
Sedaan vaiksem kui kaubalift ja see maanteemüra ikka suuresti rehvides ka kinni.
GY dB 68, Hankookil dB 69. GYst vaiksemaid rehve ei tea, endal Hankookid all. Kardan, et siin rehvides küll asi ei ole. Pigem siis universaali mürarikkus, mida mainisite. Rehvid pole aastast 2004 ja mustrijääk 2,5mm.
Edit: ja need dB, mida tootjad lubavad on sõidumüra väljast mõõtes.. R19 alla sain oli salongimüra sarnane nagu peres oleval Imprezal.Retard
Auto käis ükspäev Silberis uusi trikke õppimas.
Nimelt telefoni ei haakinud ise automaatselt külge, vaid küsis umbes 2 minuti pärast, et äkki soovid tel. ühendada, kui selle küsimuse maha magasid, siis ei ühendatud.
Ise käsitsi menüüdes sorades sai selle küll tehtud.
Nüüd toimib, lisaks ilmus juurde BT audio, saaksin tahtmise korral popp ja noortepärane olla ning Spotify´st vanu lugusi kuulata Smile
..mingi HDD ilmus ka, ilmselt saab sinna kuidagi midagi salvestada... uurib kunagi, mis ja kuidas.
Teab keegi MB rehvirõhu andurite hingeelust. Kas auto tuvastab uued andurid ise või peab neid kuidagi tutvustama?
Tahaks kevadeks teist jooksu velgi.
(06-11-2018, 06:20 PM)Laur Kirjutas: Auto käis ükspäev Silberis uusi trikke õppimas.
Ma just vahetasin, ostsin Mobiletron andurid. TPMS operative tuli veerand tunniga ekraanile, aga et rõhkusid näha pidin millegipärast arvutiga iga ratta anduri eraldi tuvastama.
Kuidas see tutvustamine Mercedesel käib?
Samas ma leidsin mingid kopeeritavad andurid...
Ma nüüd spets ei ole, aga kui sa ostad kopeeritavad andurid, siis peab töökojal olema eraldi seade mis loeb vana anduri ID ja programeerib uuele sisse. Sellisel juhul peaks tõesti saama kohe kõik funktsionaalseks.
Kui sa plaanid jätta omale mõlema veljejooksu sisse toimivad andurid, siis on ehk tõesti lihtsam kloonida olemasolevad ja sel juhul toimib rataste vahetusel asi koheselt edasi ja auto ei pea ise jälle nuputama hakkama, et mis vanadest anduritest sai.
Muidu nullist uue tutvustamine käis Stariga, läksin vastavasse moodulisse ning siis käskis ta mul igal rattal (arvuti ütles milline konkreetselt) rehvirõhku muuta vähemalt 0,3 bar. Sellega sai iga anduri ID salvestatud.
Üldiselt ma arvan, et mul oleks ka need ID numbrid üles korjanud kui mul oleks rohkem kannatust olnud ja kauem sõitnud näiteks, aga milleks ma omale selle arvuti muidu ostsin Icon_razz
Sellist tüki pole kellegil pakkuda?
A1668270204
[Pilt: 17_32.png]
USB osa huvitaks, aux on olemas ja i-phone ei ole, ei tule vista ka.
(09-11-2018, 12:22 AM)Laur Kirjutas: ...
Jajah, neid sõnu oleme kuulnud.Eusa_whistle
Muretuid kilomeetreid!Eusa_angel
Misasi on damping mat?
Rattavahetuse riistad on uuemal ajal siis eraldi koodi all...
Welcome to 212club ... oled oodatud Tulika Premiumisse Smile
56562200
(09-11-2018, 12:22 AM)Laur Kirjutas: Sellist tüki pole kellegil pakkuda?
A1668270204
Huvitav kas VW/Audi kaabel ei lähe sinna. Neid on vist rohkem liikvel, kaabel tuleb küll küljele välja, Mercedesel otse.
Peab uurima kas mul on VW/Audi kaabel alles.
Onud silberist aitasid välja ja tellisid mulle vaid USB juhtme.
Ma olen nüüd sõitnud ja kuulanud, kuid ei meeldi mulle selle auto heli, 211 oli selles osas palju parem.
Kuid saan aru ka müügimeestest, kuidagi peab ju Harman-Kardonit müüma.
Mingi aeg peaks ukse lahti harutama ja vaatama kas seal annab midagi parendada, teis kõlarisisteemi installi näol.
261000 Käigukasti õli ja filtri vahetus.
Sisse läks MB 236.14 ehk punane, kui ma kõikides wis/asra ja epc tuulates aru sain peaks see olema õige, mitte sinine MB 236.15
Vaadates varasemat arvet, siis on ka enne punane kasutuses olnud.
Välja lastes oli ka punane, suht selge ja läbipaistev.
Mootoriõli vahetasin paartuhat varem
SYNPOWER XL-III C3 5W-30 MB-Approval 229.51
Jääb veel mingi aeg difrites õlivahetus teha.
(17-11-2018, 05:18 PM)Laur Kirjutas: 261000 Käigukasti õli ja filtri vahetus.
Sinine õli on 7g Tronic PLUS-is
See on käigukasti tootmisnumbris kinni, õlivannil on ka erinevad pressimise jäljed.
Kuni numbrini 2834526 on MB 236.14 ja numbrist 2834527 on MB 236.15
Minul läheb sinine näiteks jah.
  MB W212 350CDI 4Matic 2010 kaur112 22 25,503 11-06-2021, 04:02 PM
Viimane postitus: kaur112
  Laur E320CDI-T Laur 53 41,831 12-08-2018, 10:20 PM
  S124 Laur Laur 19 16,437 14-03-2016, 05:09 PM
  S210 E320CDI T Avantgarde 99a. - Laur Laur 62 66,692 29-05-2011, 07:09 PM
Viimane postitus: HotPapa
  W124 300 TE Diisel '89a - Laur Laur 10 10,399 10-01-2010, 11:28 PM
