S500,2005,w221,Davep
Autol läbisõitu 233000 mis ka kontrollitav , alguses kahtlesin selles läbisõidus .
Vigadeks oli 8 silindri süütepool ja karterituulutus toru , need said vahetatud .
Väljast lasen tagumise sirmi ära värvida ja kapoti .
Homme panen alla 20 tollised vosseni stiilis veljed ja peale michelini lamellid , ette läheb 9*20 velg ja 255/40 rehv ja taha 10*20 velg ja rehv 285/35 .
All olevad 18 veljed koos 6-7mm rehvidega (255/45) müügiks 400 eurot .
Keskmine küttekulu 12.8 keskmise kiirusega 39km/h .
Lisadeks :
142 MEASURE PACKAGE 3
197U OBSIDIAN BLACK
202B OWNERS MANUAL AND SERVICE RECORD - GERMAN
205L LUEBECK BRANCH
223 REAR BACK REST ADJUSTMENT AND HEAD RESTRAINTS, ELE
229 PARK ASSIST
233 AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
250B MOBILO LIFE/EUROPE SERVICE PACKAGE
260B AIRBAGLABEL - GERMAN/ENGLISH
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
282 THROUGH-LOADING FEATURE VIA ARMREST IN REAR
289 LEATHER STEERING WHEEL WITH TRIM INSERT
2XXL FEDERAL REPUBLIC OF GERMANY
388 PHONE MOBILE, MTUS-SYSTEM
401 FRONT SEAT CLIMATE CONTROL
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
427 AUTOMATIC TRANSMISSION 7-SPEED
432 DYNAMICS SEAT,FRONT LEFT AND RIGHT
436 COMFORT HEADREST DRIVER AND FRONTPASSENGER
437 COMFORT HEADREST REAR
443 HEATED STEERING WHEEL
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
487 ABC SUSPENSION (ACTIVE BODY CONTROL)
524 VEHICLE PROTECTIVE COVER (FULL BODY COVER)
527 COMAND DVD APS WITH NAVIGATION
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
581 AUTOMATIC CLIMATE CONTROL
595 HEAT INSULATING+IR REFLECTG.SAFETY GLASS SIDE+REAR
600 HEADLAMPS - CLEANING EQUIPMENT
615 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
619 CORNERING ILLUMINATION
731 TRIM PIECES - WOOD BURRED WALNUT VENEER
800A LEATHER/NAPPA/SEMI-ANILINE
804A LEATHER/NAPPA/SEMI-ANILINE - BROWN
806 YEAR OF MODIFICATION
810 PREMIUM SOUND SYSTEM
813 LINGUATRONIC-GERMAN (VOICE OPERATION)
814 DVD CHANGER
863 TV-TUNER DIGITAL TO ANALOG
875 HEATED SCREEN WASH SYSTEM
881 REMOTE TRUNK LOCKING
882 INTERIOR SAFEGUARD
883 POWER CLOSING SYSTEM
889 KEYLESS - GO
985 COC PAPER EURO 4 TECHNOLOGY W. REG. CERT. PART II
A21 SHIFT BY WIRE
A22 NEW CONVERTER GENERATION
A24 JOINT FLANGE, 4-ARM 120
A29 J - VALVE BODY ASSEMBLY VGS 1 (550 NM)
F221 SERIES 221
FW LIMOUSINE
G904 TRANSMISSION CODE VERSION 04
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
K10 SOFTWARE CONTROL FOR STATIC CURVE ILLUMINATION
K11 ADAPTIVE STOP LIGHT FLASHING
L LEFT-HAND STEERING
M273 V8-GASOLINE ENGINE M273
M55 CAPACITY 5,5 LITRE
R31 18" LIGHT ALLOY WHEEL 5-SPOKE DESIGN ALL-ROUND
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
[Pilt: 22553471_1596818680375326_1750509217_o.jpg][/url][/img]
tere. kena masin
kas numbreid ei müü eraldi ?
Ilus massin, huvitav valik: ABC vedrustusega. Muretuid kilomeetreid.
(17-10-2017, 08:19 PM)arturmalcik Kirjutas: tere. kena masin
Liiga hull ooper oleks nende müümine .
(17-10-2017, 09:01 PM)hellrix Kirjutas: Ilus massin, huvitav valik: ABC vedrustusega. Muretuid kilomeetreid.
S500 ja ülespoole peaks kõik olema abc vedrustusega .
Ei ole. ABC oli ja on siiamaani lisavarustus s klassil.
(17-10-2017, 09:49 PM)shed Kirjutas: Ei ole. ABC oli ja on siiamaani lisavarustus s klassil.
Okei , eks näha ole mis see abc 20 tolliste velgedega talvel endast kujutab .
Ennem talve peaks laskma abc-.käigukasti-ja difri õlid ära vahetada .
Aga ei teagi Tartus kuhu pöörduda .
Bmw-de ja audidega märksa lihtsam .
Uute velgedega , nädalavahetusel teen sisut ka pilte .
[Pilt: Mersu_.jpg][Pilt: 22641898_1599672686756592_1805342209_o.jpg]
(17-10-2017, 09:28 PM)davep Kirjutas:
mul sama seeria numbreid juba on lihtsalt . tahtsin juurde
Täna sai proovitud plaate cd-boxi , aga ei suuda neid ära lugeda .Launchiga vaadates viga ka ei näita . On keegi sellega kokku puutunud ?
Homme läheb Silberisse hooldusesse , uurin neilt ka .
2 nädalat tagasi sai lastud Silberis hooldus teha , tahtsin ka ,et vahetakse kütusefilter ära , aga see pidi olema eluaegne ja vahetatakse koos pumbaga .Ebays on olemas kütusefiltrid eraldi müügis .
Nüüdseks auto poleeritud ja salongimatid ka keemilises käinud .Teen varsti nahahoolduse ära , siis lisan ka sisust pildid .
Plaan tellida s65 body kit , kas kellegil on kokkupuuteid Rumeeniast tellimisega ja paigaldamisega ?
Stanged , karbid , summutiotsad ja esimene võre .
Homme ülehomme tahaks ära tellida .
Olen ühe AMG stange Rumeeniast tellinud w212 masinale, sobis 96%. Järgmine kord, kui vaja tellin jällegi.
Transa oli kiire ja pakitud oli hästi.
Kaido
(02-01-2018, 09:57 PM)kaido Kirjutas: Tere
Kaido
Tellisin kogu kompoti ära , sumpaotsad, musta võre , stanged , karbid ja liistu pagassile , aga mõtlen veel kas panen selle liistu külge .
Eestis stanged koos karpidega ca 1200 euri + summutiotsad 390 ja võre 240 , Rumeeniast tellides 1100 kõik kokku . Tooted 1:1-le samad .
Plaan veel lasta väljalase ka ringi teha .
Olen ka sealt tellinud.
Kaup tuli kiirelt ja ilusti, kuid läks ka sama kiirelt (ja probleemivabalt) tagasi.
Tegu oli värske MB detailidega, äkki liiga uued vms. aga lähedalt need "AMG" detailid kriitikat ei kannatanud. Hiinakal ja hiinakal on vahe nagu ööl ja päeval.
Aga netimüüjat iseloomustab minu silmis kõige paremini kauba tagastamise edukus, ja selle eest minu lugupidamine neil.
(03-01-2018, 12:36 AM)Rolz Kirjutas: Olen ka sealt tellinud.
Ebays ka samu komplekte müüdud neil ja tagasiside on väga hea , eks näis.
Plaan tellida facelifti peeglid ka veel , esitulesid esialgu vahetama ei hakka .
(03-01-2018, 08:10 AM)davep Kirjutas:
Mul tuttav tellis kogu komplekti sealt. (Esituled ja tagatuled olid ka facelifti omad kaasas)
Kõik sobis külge ja näeb täitsa hea välja.
Kui originaali komplekti tahad siis vaata merctail.com - hinnad on muidugi hoopis teised.
(03-01-2018, 04:45 PM)evilman Kirjutas:
Sealt saab amg paketi 6000 euriga , pool minu auto maksumusest .
Head asja ei saagi odavalt.
(03-01-2018, 09:55 PM)Oliver.L Kirjutas: Head asja ei saagi odavalt.
Seda küll ja , aga kui juba head asja tahaks , siis oleks kohe pidanud soetama amg paketiga auto .
Vahepeal vahetatud abc õli , pidurivedelik , sillas õõts taastatud ,kuna ei olnud kohe võtta uut õõtsa Tartus , sillastend tehtud , rihma rullikud vahetatud .
Siiamaani sõitnud ilusti , kütusekulu 13.8 ja keskmine kiirus 41 kompuutri järgi .
80 liitriga saab 550-650 km sõita .
Järgmise hooldusega vahetan pidurikettad ja klotsid ära .
Stanged peaks jõudma 12.01 kohale , siis panen külge ja värvimisse .
Üks pilt ennem värvimist , värvitakse stanged , karbid ja kapott .[Pilt: IMG_3830.JPG]
Photo MB S500 2001a 5.0 220kw Westcoast 29 5,762 17-08-2022, 04:38 PM
Viimane postitus: Westcoast
  MB S 350, 2006, W221 - Magnus djmaq 17 12,225 19-10-2021, 11:22 PM
  MB S 500/550 L, 2005, W221 djmaq 8 4,837 24-08-2020, 07:54 PM
  Mb s500l 2005 w221 fedja fedja 4 4,224 23-09-2019, 07:41 AM
Viimane postitus: Oliver.L
  Mercedes Benz E200 Kompressor, 2005, W211, Plinger Plinger 0 1,984 12-08-2019, 08:48 PM
Viimane postitus: Plinger
  Mercedes-Benz C220 CDI, 2005, w203 - m2giorav m2giorav 32 35,408 15-05-2019, 09:32 PM
Viimane postitus: m2giorav
  MB E280T CDI, 2005 W211 rivo rivo211 9 5,597 29-01-2019, 08:23 PM
Viimane postitus: Black66
  Mb e400cdi, 2005, w211 - arturmalcik arturmalcik 17 16,983 20-06-2018, 09:35 AM
Viimane postitus: herki
  Minu C240 4MATIC 2005 Eric 9 8,770 20-12-2017, 10:44 AM
Viimane postitus: Eric
  Mercedes-Benz CLK200K, 2005, C209, Kevtal kevtal 34 36,302 17-11-2017, 05:34 PM
Viimane postitus: kevtal
