  • 3Hääli - 3.67 keskmine
Kirjuta, küsida võib kõike!
VIN: WDB4633331X124501 dekodeering (soov. inglise-keelne)?
(18-09-2011, 07:51 PM)nostromo Kirjutas: VIN: WDB4633331X124501 dekodeering (soov. inglise-keelne)?
Название val
fin
vin WDB4633331X124501
whc WDB
chassbm 463333
chass_ident 1X124501
type 463
subbm1 333
subbm2
auxiliary_drive
body 463831 10
body_code 3
delivery_date 010216
engine 628962 40 004386
front_axle1 730306 1R 115359
front_axle2
heater
interior
lights
model_idx 1
odometer
order_num1 6023500504
paint1 6891
paint2
paint3
paint4
paint5
platform
production_num1 6126044
production_order_ref
rear_axle1 741144 1R 115548
rear_axle2
release_date 010214
retarder
rims
service_num
steering 765503 10 N01022
trailer
transfer_case 750654 00 021132
transmission 722638 02 700497
vin_dc
vinwhc
winch
wiper
Code Текст
^^^        Unknown
C75        LOWER BODY PROTECTION
C77        RADIATOR GRILLE WITH CHROME EFFECT
C78        2 STAINLESS STEEL DOOR SILL MOLDINGS, ILLUMINATED
D27        ELECTRIC SLIDING/LIFTING ROOF
EL1        Unknown
EM9        TV TUNER WITH ANTENNA AMPLIFIER
ET4        Unknown
ET7        Unknown
GE9        AUTOMATIC TRANSMISSION WITH SHIFT LOCK
H10        HEATER F. DRIVER AND FRONT PASS. SEAT
H11        HEATER FOR REAR BENCH SEAT
H12        Unknown
IX1        Unknown
I86        Unknown
J44        ULTRASOUND BACKUP ASSIST
MR7        Unknown
P48        REAR MUD FLAPS
Q55        TRAILER HITCH, REINFORCED BALL HEAD, LOW D 96/4
RB9        SPARE WHEEL COVER, STAINLESS STEEL
RL8        18" LIGHT ALLOY WHEELS
SM7        MULTICONTOUR SEAT, DRIVER
T84        SIDE-MOUNTED STEP
U46        LEATHER INTERIOR EQUIPMENT
VL1        STEER. WH. + SEL. LEV. IN LEATHER/BURL WOOD VERS.
VL2        VELOUR FLOOR MATS
VL3        EXCLUSIVE PACKAGE
VL4        RUBBER MAT FOR LOAD COMPARTMENT
V18        INTERIOR TRIM IN BLACK
V56        WOOD TRIM BURRED WALNUT ROOT
W70        Unknown
XU1        GERMAN LABELS / PRINTED MATERIAL
XY0        Unknown
X02        MODEL BADGE FOR SPECIFIC COUNTRY
X30        VEHICLE REGISTRATION BOOK
YF4        CD-ROM FOR AUTO PILOT SYSTEM, GERMANY
YF9        GARAGE DOOR OPENER INTEGRATED INTO INSIDE MIRROR
6891       Unknown
Название Value
AF1SV C006015062
AF2SV
ENGSV
CASESV C011503289
AR1SV C004015071
AR2SV
TRANSSV
MTRSAC
kas ka minu VINile leiab asjalikuma vastuse? Netist midagi nii põhjalikku pole näinud? WDB1240511B213993
Tänud ette
(19-09-2011, 12:36 PM)põhh Kirjutas: kas ka minu VINile leiab asjalikuma vastuse? Netist midagi nii põhjalikku pole näinud? WDB1240511B213993
Tänud ette
EPC
Identification number: WDB1240511B213993 6
Chassis
Sales designation: 300 CE-24
Order number: 0 - 229 12608
Datacard
Paint code 1: 199 APPLICATION CODE FOR COMPONENT PROCESSING
Equipment: 261 No code designation available
Engine no.: 104980 12 008076
Transmission: 722359 03 360956
SA code
211 AUTOMATIC LIMITED SLIP DIFFERENTIAL (ASD)
221 LEFT FRONT SEAT, ELECTRICALLY ADJUSTABLE
240 OUTSIDE TEMPERATURE INDICATOR
261A LEATHER BLACK
300 - 20101110 - COLLISION MINIMIZATION BRAKE INTERV./WARNING (CMS)
300 - 19880501 - STORAGE BOX IN FRONT TRAY
412 - 19951002 - ELECTRIC SLIDING ROOF
412 - 19980716 - ELECTRIC SLIDING ROOF WITH TILTING DEVICE
420 AUTOMATIC TRANSMISSION 4-GEAR
430 HEADREST IN THE REAR, LEFT AND RIGHT
444 No code designation available
511 RADIO MB EXQUISIT WITH VK,RDS (PANASONIC)
531 AUTOMATIC ANTENNA
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
570 FOLDING ARMREST, FRONT
580 AIR CONDITIONING
600 HEADLAMPS - CLEANING EQUIPMENT
620 AIR POLLUTION CONTROL
812 - 20100219 - BLU-RAY PLAYER
812 - 19951002 - REAR-MOUNTED LOUDSPEAKER
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
Venelaste leht
fin
vin WDB1240511B213993
whc WDB
chassbm 124051
chass_ident 1B213993
type 124
subbm1 051
subbm2
auxiliary_drive
body 01526
body_code
delivery_date
engine 104980 12 008076
front_axle1
front_axle2
heater
interior 261
lights HELLA
model_idx 1
odometer
order_num1 0-22912608
paint1 199
paint2
paint3
paint4
paint5
platform
production_num1
rear_axle1
rear_axle2
release_date
retarder
rims
service_num
steering
trailer
transfer_case
transmission 722359 03 360956
vin_dc
vinwhc
winch
wiper BOSCH 900308
Code Текст
300 Unknown
412 Unknown
444 Unknown
812 Unknown
261 TYPE DESIGNATION ON FENDER / SIDEWARD DELETION
VIN koodi järgi saab infot järgnevalt:
300CD, 1984
Suured tänud, Toomaz!
Kuna otsing mulle midagi huvitavat akude kohta ei rääkinud, siis kas keegi oskab soovitada akut, mis meeldiks 300ce-24'le kõige rohkem? Käivitusvoolu poolest nimelt, mahutavus ja tootja selguvad arvatavasti juba poes.
Poes leitakse kataloogist sinu autole sobivate näitajatega aku, tootjafirma valid rahakoti järgi.
Millise tootja esiamorte W123'le eelistada?
kuidas kütusepumpa peale keerata, et sa saaks rohekm kütust? kas seda polti lahtipoole või kinnipoole ? 3.0D om603
(20-09-2011, 04:31 PM)põhh Kirjutas: Suured tänud, Toomaz!
WTF? Mis ajast lahustipõletajale tõsist käivitusvoolu vaja on?Icon_eek
Aku osta nii suur, kui alusele mahub ja nii uue tehnoloogiaga, kui rahakott kannatab. AGM oleks muidugi parim, kuid mingit sisulist vajadust selle järele ei ole. Mina võtaks akupoe pakkumistest sobiva Ca (või suisa hõbeaku, kui raha jagub).Rolleyes
Mingist 500 A peaks nagu piisama selle mootorikese käimavedamiseks. Ja see peaks igast enesest lugupidavast akust tänapäeval ka leiduma. Tõsi, ma pean silmas CCA numbrit ja mitte seda kõige suuremat aku kleepsult...
(21-09-2011, 08:19 PM)Kaltsyum Kirjutas: kuidas kütusepumpa peale keerata, et sa saaks rohekm kütust? kas seda polti lahtipoole või kinnipoole ? 3.0D om603
Neid "polte" oli kolm (osasi lahti, teisi kinni), alles hiljuti oli sellest ka foorumis üks teema.
Millise tootja juhet ma peaks siia otsima? Teine variant, milline ots mida juhib(+ / -), saab ise äkki uue meisterdada. Külmad ajad tulemasIcon_smile
[Pilt: 96473-juhe_1.JPG]
(26-09-2011, 09:38 AM)2015c Kirjutas: Millise tootja juhet ma peaks siia otsima?
Kas kaanel kirja ei ole? Defa ja Calix on sellised pisikesed.
Vahelduvvoolul ei ole vahet, kumb ülemistest on kumb soon, alumine on kaitsemaa. Aga ma tungivalt soovitan iseleiutamisest loobuda - üsna kerge on kedagi ära tappa niimoodi.
Kuskil pole midagi kirjas. Juhe tuleb siit eest sisse ja siis läheb kaheks, üks mootoriblokki ja teine salongi kus tavaline toa 220v, pistik, puhuri jaoks.
Ehk pöördud mõne firma poole, kes analoogseid seadmeid paigaldavad, ilmselt saad neilt ka vajaliku kaabli.
Tere. Meil töö juures kummitab mitu aastat küsimus, kes on Ott Leplandi isa.Icon_lol Sellest oli kunagi juttu Sky Plus-is, aga siis selget vastust ei saanud.
(27-09-2011, 07:46 PM)John Smith Kirjutas: Tere. Meil töö juures kummitab mitu aastat küsimus, kes on Ott Leplandi isa.Icon_lol Sellest oli kunagi juttu Sky Plus-is, aga siis selget vastust ei saanud.
Isadega on keeruline, seda vahel ei te emagi 100% täpsusega, kuigi tema vähemalt aimab...Icon_lolIcon_lol Tõsised teemad muidugi mida töö ajast arutada Icon_razz
[Pilt: stress.jpg]
Oskab ehk keegi nõu jagada.
Mis järjekorras peaks w201-l plokikaane polte kinni keerama?
The best or nothing
(02-10-2011, 10:27 PM)sten130 Kirjutas: Oskab ehk keegi nõu jagada.
esiosa 8 4 2 6 10 tagaosa
7 3 1 5 9
Tänud Wink
The best or nothing
Juba mõnda aega plaanis soetada jõuvõti/dünamomeeter/newtonmeter millel skaala kuskil 0-70Nm.
Oskab keegi neist midagi rääkida, millist kindlasti mitte osta jne.
Silma jäi üks selline pakkumine
http://www.auto24.ee/products/detail_pro...?id=452517
  Võib kustudada! Minister 0 423 08-01-2023, 02:19 PM
Viimane postitus: Minister
  Naisperele kõike paremat naistepäevaks! Heinar 18 16,962 08-03-2011, 11:37 PM
Viimane postitus: taaviw126
  Palju võib maksta?... kpokyc 0 3,385 03-08-2008, 11:09 PM
Viimane postitus: kpokyc
  Palju võib maksta rumulast nahkistmed C klassile (W202) ? Scratch 8 8,992 14-12-2007, 07:04 PM
Viimane postitus: Uku
Heart Kuidas õnn võib uksele koputada. kuld 27 21,224 05-10-2007, 11:51 AM
Viimane postitus: Innu
  Mida kõike võib vanast küünist leida :) kalacompany 6 7,582 17-03-2007, 06:17 PM
Viimane postitus: /////AMG
Kasutaja, kes vaatavad seda teemat: 13 külali(st)ne
