Postitused: 1,179
Teemad: 69
Liitus: Feb 2009
Ilmselt toimib nii, nagu tehases oleks manuaal alla pandud. Ise olen ka selle tee läbinud ja ei hakanud ei ajud lolli mängima, ega muud asjad. Mul oli enda autol peal veel ASR ja see jäi ka tööle, seega edu!
CE420 v8
Postitused: 133
Teemad: 26
Liitus: Oct 2015
Mis ülekandega differ on 162kw atm-l ja 142kw 2.8 manuaali,kuskil Mercedes-Benz diffrite tabelit ei ole?
Postitused: 937
Teemad: 18
4
Coup?s of the series 124
Mercedes-Benz type 300 CE-24
Gearbox 5-speed gear shift
Availability Series
Shifting Feed control
Clutch Single-plate dry clutch
Type of gearbox Pinion change gear
Synchromesh gears I - V
Gear transmission I. 4,15; II. 2,52; III. 1,69; IV. 1,24; V. 1,0; R. 4,15
Differential ratio 3,27
Maximum speed 237 km/h
Accelerations 8,0 s
Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons
Fuel consumption 8,1/10,0/14,8 l
acc. to guideline 80/1268/EWG; values for 90 km/h / 120 km/h / city cycle
Gearbox 4-speed autom. gear shift
Availability by request
Shifting Switch lever in car center
Clutch hydr. torque converter in autom. gear
Type of gearbox Planet gear
Synchromesh gears
Gear transmission I. 3,87; II. 2,25; III. 1,44; IV. 1,0; R. 5,59
Maximum speed 232 km/h
Accelerations 7,8 s
Fuel consumption 8,9/10,8/14,0 l
Gearbox 5-speed autom. gear shift
Availability by request (from 01.90)
Synchromesh gears
Gear transmission I. 3,87; II. 2,25; III. 1,44; IV. 1,0; V. 0,75; R. 5,59
Differential ratio 3,69
Accelerations 7,8 s
Fuel consumption 8,3/9,9/14,6 l
Limousines of the series 124
Mercedes-Benz type 280 E
Availability Series
Gear transmission I. 3,86; II. 2,18; III. 1,38; IV. 1,0; V. 0,80; R. 4,22
Maximum speed 230 km/h
Accelerations 9,1 s
Fuel consumption 7,9/9,6/14,6 l
setud sõitsid seciga
Postitused: 133
Teemad: 26
Liitus: Oct 2015
06-11-2015, 10:09 AM
(Seda postitust muudeti viimati: 06-11-2015, 09:44 PM ja muutjaks oli Valgma.)
(Y)
Aga kas ce300 5atmil 3.06/07 ülekandega differ pole.
Mõlemad typ 210!?
Kuskilt sobiva 3.7 ülekandega typ210 LSD-d võimalik leida?
Edit:3.69 on juba all.
Postitused: 133
Teemad: 26
Liitus: Oct 2015
Vahepeal sai mässatud anomaaliaga, mis kohe peale swapi autot vaevas-vahepeal poos kiirendades hinge kinni,mõned korrad suri sõidupealt välja,gaasid 10x üle normi ja kütusekulu meeletu.Sai käidud Speedsteris,viga oli 2 tunniga teada.Vanahea lambda pani näkku.Töötas-ei töödanud.
Nüüd liigub normaalselt,tahho käib sujuvalt põhja.
Tänud Hannesele,kiire töö ja abivalmiduse eest.
Aga-kasti anomaalia jäänud veel lahendada-kast koliseb julmalt.Sai siit foorumist kast ostetud aga tundub et see täielik prügi.
Mercedes-Benz kastid kõik nii vedelad?Doglegi panema ei hakka,neid vist väga saada pole mõistliku raha eest?
Tava kastid kõik ühetugeva sisuga või mõni parem?
Praegu 2.8 145kw kast,selle käigud parajad
Postitused: 8,667
Teemad: 110
36
04-12-2015, 09:18 AM
(Seda postitust muudeti viimati: 04-12-2015, 09:18 AM ja muutjaks oli v6sa.)
Misasi koliseb? Käigukast? siis peaks juba laiali olema.
Kindel, et kardaani tugilaager ikka olemas on enam?
Manuaalkastid surevad räpaka käiguvahetuse ja hooldamatuse tõttu lihtsalt ära.
Postitused: 1,340
Teemad: 74
2
04-12-2015, 09:23 AM
(Seda postitust muudeti viimati: 04-12-2015, 09:29 AM ja muutjaks oli sm. pelle.)
Ma prooviks õnne korra veel tavalise viiesega kuigi siduripauke vist ükski ei kannata. Uuri sprinteri kaste, dislamehed on neid kasutanud aga nii puusalt pakkudes kui isegi ploki külge läheb võib hooratta, kasti kinnitustega ja kardaaniga ehitamist tulla. Mul vana viiene peaks kuskil alles olema, kui endaoma laiali lased võin õllede vastu vahetada. See ka elu näind aga jäi veel ühte tükki.
Kui lõhkuda tahad oleks mõistlik ikkagi ühe teise tootja kast võtta.
Edit: mis hooratas ja kast lõpuks said. Mb'l oli ka vist neid kahe massilisi. Kui hooratas 1 massiline aga kast 2 massilise küljest siis kast võibki hakkata kolisema. Selle pärast ma väga ei muretseks siis.
Postitused: 1,234
Teemad: 101
Liitus: Sep 2008
3
Pööra tähelepanu 126 koodiga algavatele kastidele rohkem. Mul pidas viimane eksemplaar imeläbi 3,2 turbo otsas terve suve vastu. Ilmselt kestab originaal mootori otsas kõige harilikum viiene ka, peasi et korralik oleks.
Naftapress.
Postitused: 133
Teemad: 26
Liitus: Oct 2015
126 koodialgusega siis w126 oma?
Kasti hammakad teevad häält kastis.Hooratas 2 massiline,lühikese võlliga kast- kõik 2.8 küljest.Muu kõik põhjalt ok.
Postitused: 1,234
Teemad: 101
Liitus: Sep 2008
3
Ei ole, neid kasutati vist suurema mootoriga bensukatel võibolla mõnedel disladel ka. Aga need on pika võlliga.
Naftapress.
Postitused: 133
Teemad: 26
Liitus: Oct 2015
Kas ASR i mootori lämmatamisest libedaga oleks võimalus vabaneda.Ühesõnaga libedaga mootori piiramise delete?
Postitused: 1,179
Teemad: 69
Liitus: Feb 2009
Kunagi eemaldasin, ASRi hoovastiku gaasi ahelast siis toimis. Juhtus aga see, et gaasipedaal oli jäik
CE420 v8
Postitused: 5,353
Teemad: 266
Liitus: Sep 2007
7
kas teema autost tuleb ?
Postitused: 133
Teemad: 26
Liitus: Oct 2015
Vist mitte,pean lähiajal kahjuks vist müüki panema.
Postitused: 133
Teemad: 26
Liitus: Oct 2015
Kastivahetus jälle käsil,Praegu kahemassiline aga nüüd panen ühemassilise hooratta ja kasti,kas Ühemassilise kastil kahvel erinev v ainult survelaager?äkki kellegil on korralikku survelaagrit pakkuda harjumaal kiiresti,auto vedeleb tõstukil ja homme poed ka kinni.
Postitused: 133
Teemad: 26
Liitus: Oct 2015
Kahvli serv käib korvi,tundub lühike olevat käik,homme tellin ühemassilise kasti survelaagri.
Kellegil on nt r126 algusega v suvalist pikavõlliga kasti,kust mõõta kahvli,kahvlitiku pikkust?
Postitused: 133
Teemad: 26
Liitus: Oct 2015
Sai ajutist lahendust proovitud ja kahvli tikku korvipoole cm viidud ja silindri varrast samapalju pikemaks tehtud.Töötab,käigud ka kõik ok(Y)
