M: 15" type-r 4+4ohm ja Alpine mrp-m850 monoblock
Häälestus 33hz. kast valmistatud mdf-ist ja seest üle tehtud klaasriidega. Pealmise plaadi paksus on pordi kohast näha. Korralik tugev kast. Sub ja võim töötavad kenasti nii nagu peavad.
Võim:
Performance
RMS Power Output 4ohms (Watts x Channels) 500 x 1
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 800 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged N/A
Minimum Impedance Unbridged 2
Best Frequency Response 20-200 Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 70 dB
Input Voltage 14.4v
Features
Amplifier Class D
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 24 dB/oct
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) N/A
Bass Boost 0-12dB
Bass Boost Frequency 50 Hz
Fan Cooled No
Fuse Rating 25 x 3
Speaker Level Inputs Harness
Preamp Outputs No
Width (inches) 16-3/8
Height (inches) 2-3/8
Depth (inches) 9-9/16
Sub:
15" Dual 4 ohm Type-R Subwoofer
Power Handling:
Peak: 2000 watts
RMS: 750 watts
Parabolic kevlar/pulp fiber cone
High amplitude multi-roll santoprene surround
Cast aluminum perimeter vented heat transfer frame
Compound Radius Curve (CRC) Motor structure
Spiral cut aluminum former with high temperature DVC Winding
Radial Vented (VC) heat sink and Airflow Management System
Mirrored progressive nomex spiders with reinforced layer integrated tinsel leads
[Pilt: 158510584680.jpg]
[Pilt: 158510582631.jpg]
Kuulamisvõimalus olemas. Huvi korral saab kasti mõõdud. Tehtud c4 avanti esialgselt.
Hind: 400€
Priva või 567I9I38
  ///// ALPINE SWD-2030 AKTIIV-SUBWOOFER 350W CLASS D ronnythebeast 0 1,881 07-03-2021, 09:27 AM
Viimane postitus: ronnythebeast
  ALPINE SPG-12KIT NOM 250W RMS MAX 800W 12" 2/4 OHM KOMPLEKT ronnythebeast 0 3,108 07-03-2021, 08:38 AM
  Müüdud- kustutada:Woofer Alpine PWE S8 madis71 0 4,506 27-01-2020, 11:36 AM
Viimane postitus: madis71
  MÜÜDUD!!! Alpine CDE-178BT4 x 50w 6 x RCA USB AUX-IN Aegviited Ronny The Beast 0 2,147 27-01-2019, 11:17 PM
Viimane postitus: Ronny The Beast
  MÜÜDUD!!! Mercedes Audio 20 CD MF2770 W211 S211 E-Class Alpine originaalstereo Ronny The Beast 0 3,645 05-01-2019, 01:44 PM
  /////ALPINE KASSETT CD MINIDISC HI-END HI-FI STEREOD AUX-IN Ronny The Beast 0 2,078 22-11-2018, 01:54 AM
  MÜÜDUD!!! /////ALPINE IVA-D310R KOMPLEKT Ronny The Beast 0 2,505 28-04-2018, 08:28 AM
  MÜÜDUD!!! ALPINE SPR-50C NOM 100W RMS MAX 300W 4 OHM komponentsüsteem Ronny The Beast 0 2,351 28-04-2018, 08:18 AM
  M: DD LE-M08 & Alpine MRV-M500 S.K.S 0 2,207 05-01-2018, 12:49 AM
Viimane postitus: S.K.S
  Mis: Alpine Type R "12 W211 univ.-Mersule tehtud kastiga +Bassface võimendi DaddyV 0 2,721 11-10-2017, 07:39 PM
Viimane postitus: DaddyV
