varustuse koodid
kas keegi tarkadest äkki seletax laiali mida tähendavad w124 koodid 603 ja 800....
603 - headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (from 01.08.1971)
800 - Change of year of model, last figure shows new model year
eDiCk Kirjutas:603 - headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (from 01.08.1971)
last figure of what?
mul 603 näitab: la 7-spoke design 17 zoll ;evolution:????
viimane number näitab mis aasta facelift autol on. Näiteks 804 - 2003 aastal toodetud autol on 2004 a tuled, sisu jne.
intsuonu Kirjutas:
kuule iga vin-iga näitab erinevad asjad
kas ei ole mõistlikum vin-kood siia panna
eDiCk Kirjutas:
intsuonu Kirjutas:
küsi mis sind huvitab
VIN WDB1240911F123248
Model 300 TE-24,AMG 300 TE 3.4
Chassis 1240911F123248
Engine 104980 12 000945
Transmission 722359 03 280761
Order 0 9 569 39358
Delivery date 21.09.89
Dealer Sweden (569)
Interior cloth grey (068)
Paint
568 signal red (T) (с 01.01.1963 по 31.12.1993)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
236 special lamp switching - daytime running lamps (с 01.04.1985)
special light wiring for Norway and Sweden
240 outside temperature indicator (с 01.03.1982)
341 additional lamp (с 01.09.1982)
412 electric sliding roof with tilting device (с 01.07.1983)
420 automatic transmission, floor shift (с 01.01.1963)
524 paintcoat preservation (с 01.01.1964)
534 antenna, mechanically operated, without radio set (с 01.01.1963 по 30.11.1990)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
603 headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (с 01.08.1971)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
673 high-capacity battery (с 01.01.1964)
800 Change of year of model, last figure shows new model year
812 rear-mounted loudspeaker (с 01.11.1974)
825
873 seat heater for left and right front seats (с
eDiCk Kirjutas:küsi mis sind huvitab
Order 0 9 569 39358
Dealer Sweden (569)
Paint
Options
825
kysimus oligi selles 603-es..siin näitab üht a olen vaadanud ka mujalt seal see teine jutt..ja see 800.. kui saan õigesti aru siis kuna viimane 0
siis õige aasta on 90..paranda kui eksin..
ei
see on uuem aasta mudel, näiteks restyle ja mitte restyle
eDiCk Kirjutas:ei
kusagilt näitas:year of modification 99/1....
  S 210 hüdroamortide osade koodid? kriipspois 5 4,731 17-12-2014, 10:48 PM
Viimane postitus: kriipspois
  w211 varustuse kood 485 ja 551?? max07 7 6,168 23-02-2009, 12:05 AM
Viimane postitus: eDiCk
