18-10-2006, 10:53 PM
Palju 2,3 r4 mootoriga w124 masinale mootoriõlivahetuseks õli osta? mitu liitrit ?
õlivahetus w124 2,3
19-10-2006, 12:16 AM
[quote=sassjass]
Palju 2,3 r4 mootoriga w124 masinale mootoriõlivahetuseks õli osta? mitu liitrit ? 5 liitrit
19-10-2006, 06:37 PM
Mercedes-Benz
Type E,CE,T,TE 230 E (124) (1985-1987) -------------------------------------------------------------------------------- Engine M 102 Capacity 4,5 liter Filter Capacity 0,5 liter Use: Normal Service intervals: Change 10000 km / 12 months MaxLife Diesel 10W-40 MaxLife 10W-40 SynPower 5W-30 Transmission, manual Capacity 1,5 liter Use: Normal Service intervals: Check 20000 km ATF Type D Transmission, manual Capacity 1,3 liter Use: Normal Service intervals: Check 20000 km ATF Type D Differential, rear Capacity 1,1 liter Use: Normal Service intervals: Check 20000 km HP GL-5 90 Transmission, automatic 722.408 Capacity 6 liter Use: Normal Service intervals: Check 20000 km Change 60000 km SynPower ATF ATF Type D Hydraulic levelling system Capacity 2 liter Use: Normal Service intervals: Check 20000 km Contact Technical Service of Valvoline Hydraulic brakes/clutch system Capacity 0,55 liter Use: Normal Service intervals: Check 20000 km Change 12 months Brake & Clutch Fluid DOT 3 & 4 Power steering Capacity 1 liter Use: Normal Service intervals: Check 20000 km ATF Type D Grease Points/nipples, wheel bearings, front Use: Normal Service intervals: Check 20000 km Multi Purpose Grease Cooling system Capacity 9,5 liter Use: Normal Service intervals: Check 20000 km Change 36 months Coolant Maxlife AF Coolant AF Extra Valvoline
If you want to make God laugh, tell him your future plans |
| W124 fännidele | MAV | 0 | 317 |
18-10-2026, 10:10 PM Viimane postitus: MAV |
| 1991a w124 pritsepea | S3pp | 3 | 742 |
| w124 süüteluku vahetus | kraabus | 2 | 1,156 |
| Kuidas eemaldada w124 esiukse aknatõstuki mootorit kui klaas ei liigu? | kraabus | 2 | 894 |
| W124 "duo valve" (puhub sooja) | Manifesto | 3 | 1,410 |
W124 1989_alu velg v. terasvelg? | squirrel9 | 4 | 1,264 |
| w124 om606 käigukast/sidur | eenupeenu | 3 | 1,231 |
| Mure W124 pööretega | spy4 | 21 | 11,801 |
| w124 karbikatete tüüblid | IndrekJ | 3 | 1,235 |
| W124 3.0d mootori mure. | M1X | 4 | 1,781 |
