õlivahetus w124 2,3
Palju 2,3 r4 mootoriga w124 masinale mootoriõlivahetuseks õli osta? mitu liitrit ?
[quote=sassjass]
5 liitrit
Mercedes-Benz
Type E,CE,T,TE
230 E (124) (1985-1987)
Engine M 102  Capacity 4,5 liter
Filter Capacity 0,5 liter
Use: Normal
Service intervals:
Change 10000 km / 12 months
   MaxLife Diesel 10W-40
MaxLife 10W-40
SynPower 5W-30
Transmission, manual   Capacity 1,5 liter
Use: Normal
Service intervals:
Check 20000 km
   ATF Type D
Transmission, manual   Capacity 1,3 liter
Use: Normal
Service intervals:
Check 20000 km
   ATF Type D
Differential, rear   Capacity 1,1 liter
Use: Normal
Service intervals:
Check 20000 km
   HP GL-5 90
Transmission, automatic 722.408  Capacity 6 liter
Use: Normal
Service intervals:
Check 20000 km
Change 60000 km
   SynPower ATF
ATF Type D
Hydraulic levelling system   Capacity 2 liter
Use: Normal
Service intervals:
Check 20000 km
   Contact Technical Service of Valvoline
Hydraulic brakes/clutch system   Capacity 0,55 liter
Use: Normal
Service intervals:
Check 20000 km
Change 12 months
   Brake & Clutch Fluid DOT 3 & 4
Power steering   Capacity 1 liter
Use: Normal
Service intervals:
Check 20000 km
   ATF Type D
Grease Points/nipples, wheel bearings, front
Use: Normal
Service intervals:
Check 20000 km
   Multi Purpose Grease
Cooling system   Capacity 9,5 liter
Use: Normal
Service intervals:
Check 20000 km
Change 36 months
   Coolant Maxlife AF
Coolant AF Extra
Valvoline
  1991a w124 pritsepea S3pp 3 742 09-06-2025, 01:31 PM
Photo W124 1989_alu velg v. terasvelg? squirrel9 4 1,264 29-02-2024, 10:30 AM
  Mure W124 pööretega spy4 21 11,801 19-03-2023, 11:28 PM
  W124 3.0d mootori mure. M1X 4 1,781 29-11-2022, 09:33 PM
