M:Myydud
Kuna uus vana silmapiiril siis läheb müüki paar vanakest.
91a W140
ls.ca 230tkm
värvus hõbemet.
hall riidesisu
mootor 3.2R6 170kw
käigukast-automaat
orig.velg16"
kliima,el.aknad,katuseluuk,ABS,ASR
uus aku
roostet ei ole.
rootsi reg.
win.wdb1400321A001504
hind 2300.-eur
[Pilt: 100_0277.JPG]
[Pilt: 100_0278.JPG]
87a W126 SEL
ls.ca 370tkm
värvus helepruun met.
mootor 4.2v8 160kw
käigukast-automaat
pruun nahksisu,4xel.aknad,mäludega el.istmed,4x istmesoojendus,püsikiirusehoidja,kliima,ABS,katuseluuk,v.velg15"
uus aku
esineb roostet,läbivaid auke ei ole,põhi ok.
rootsi reg.
win.wdb1260351A329576
hind 2200.-eur
[Pilt: 100_0269.JPG]
[Pilt: 100_0265.JPG]
[Pilt: 100_0268.JPG]
Tel.+46700598508 või PS
Väga kena 126 Thumbsup
Название val
fin
vin WDB1260351A329576
whc WDB
chassbm 126035
chass_ident 1A329576
type 126
subbm1 035
subbm2
auxiliary_drive
body 04878
body_code
delivery_date
engine 116965 12 038321
front_axle1
front_axle2
heater
interior 273
lights BOSCH
model_idx 0
odometer
order_num1 0756920083
paint1 441
paint2
paint3
paint4
paint5
platform
production_num1
production_order_ref
rear_axle1
rear_axle2
release_date
retarder
rims
service_num
steering
trailer
transfer_case
transmission 722324 02 918711
vin_dc
vinwhc
winch
wiper 000000
Code Текст
223 REAR BACK REST ADJUSTMENT AND HEAD RESTRAINTS, ELE
226 FOOTRESTS IN THE REAR
227 ASHTRAY, CIGAR LIGHTER AT REAR, L AND R
236 SPECIAL LAMP SWITCHING - DAYTIME RUNNING LAMPS
240 OUTSIDE TEMPERATURE INDICATOR
241 FRONT SEAT LH ELECTRIC ADJUSTABLE WITH MEMORY
242 FRONT SEAT RH ELECTRIC ADJUSTABLE WITH MEMORY
256 Unknown
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
341 ADDITIONAL BLINKER LAMPS
406 Unknown
412 Unknown
446 Unknown
506 Unknown
524 PAINTWORK - PRESERVATION
532 Unknown
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
586 Unknown
592 ALL-ROUND WD-GREEN GLASS,HEATED REAR WINDOW-VSG
603 Unknown
611 EXIT LIGHTS FOR DRIVER DOORS
624 Unknown
630 ECE - WARNING TRIANGLE
640 15-HOLE LIGHT ALLOY RIMS
673 HIGH-CAPACITY BATTERY
731 WOOD TRIM BURRED WALNUT ROOT
807 AEJ 06/1/M/X
812 Unknown
872 Unknown
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
441 ADJUSTABLE STEERING COLUMN
273 TELEPHONE PRE-INSTALLATION D-NET MOBILE
www.lesven.ee
Suur tänu ReinGSM.
Püsikiiruse hoidjat seal 126-l nimekirjas ei ole. See paigaldatud 99-aastal. Toode VDO compact tempostat.Kõik paigaldusjuhised,joonised ja muu vajalik dokumentatsioon ka olemas. Autol kahjuks serviseraamatut säilinud ei ole aga on olemas kaust koos remondikohtadest saadud arvetega teostatud töödest. Ajalugu alates 97.aastast ja läbisõidust 292717 teostatud töödest olemas kuni 2002 aastani. Teostatud töösid 116 807.-SEK.-i eest. 2002 a. lõpus läbisõit 339750km. 97.a ja läbisõit 294500km. tehtud mootori remont,osade maksumus 24219.-sek. Peale 2002 aastat siis auto kokku sõitnud vähem kui 30tkm ja viimased 3 a.ainult seisnud. Kel huvi siis saab endale korraliku projektika ja tõsisele huvilisele hind ka kivist ei ole. Autot saab näha eestis esmasp.25.07.
Varsti läheb kuulutus ka auto24.
Kas 140 ka esmaspäeval Eestis.
(21-07-2011, 05:47 PM)ALFFAA Kirjutas: Kas 140 ka esmaspäeval Eestis.
140 mitte.Esialgu. Link auto24 126 SEL
SEL asub Tallinnas nüüd. Täpsem info tel. 5020001
UP! Mõlemad autod veel saadaval.
W126 420SEL ootab uut omanikku Tallinnas,Pääskülas.
Info 5020001 Üllar.
UP! Veel saadaval.
Up!
Kuna kindlustus saab läbi ja pole vajadust nii paljude autode järele siis w140järgmine nädal eestis.H:2100.-
Täiesti s6idukorras ja kehtiva ylevaatusega.
Terv
  Myydud Daniel87 3 4,189 07-02-2017, 10:58 AM
  M:MB124 300TE24-92 Myydud! itbilen 2 2,497 29-10-2012, 11:52 PM
Viimane postitus: itbilen
  Myydud MBw140 0 2,542 12-12-2011, 09:21 PM
Viimane postitus: MBw140
