M: Mootor M110.985 (2.8, R6, 136kw)
Müüa kõnealune mootor, pärineb vana 280SE pealt
PILDID
All M110 engines have a displacement of 2.7 L; 167.6 cu in (2,746 cc) and a bore and stroke of 86 mm × 78.8 mm (3.39 in × 3.10 in). Firing order is 1-5-3-6-2-4. Amount of coolant in the radiator was 11 litres. from 1972 and 12 litres from the 1980s and on. Amount of oil (lubricant) in the engine was 6 litres. The lubrication system was pressure circulation lubrication system. A number of valves was 1 intake, 1 exhaust with V-shaped overhead configuration. Valve operation was 2 top camshafts and camshaft drive was a duplex roller-type chain.
Power output: 132 kW (179 PS; 177 hp) at 6000 rpm up to April 1978; 136 kW (185 PS; 182 hp) at 5800 rpm from April 1978.
H: 350.-
  o:w204 universaali kojamehe mootor Dominic 0 67 21-03-2024, 02:39 PM
Viimane postitus: Dominic
  O: W201 Tagumine parem tuli, kojamehe mootor, kellaplokk, juhi turvavöö rihm maxim1655 2 169 11-12-2023, 12:29 PM
  M: W211 220d 125kw OM646.821 Mootor; 2007-2009, hind: oktsionil ash 0 145 31-10-2023, 11:17 AM
Viimane postitus: ash
  M: M113 5.0 225kw mootor Krl167 0 221 11-09-2023, 05:53 PM
Viimane postitus: Krl167
  M: M112 2,4L mootor dad 1 290 17-07-2023, 10:47 PM
Viimane postitus: dad
  O: W123 või muu roolivõimu pumba, mootor OM616 2,4d comoon 0 104 06-07-2023, 10:04 AM
Viimane postitus: comoon
  M: om605 NA mootor varuosadeks jarxx 0 183 04-07-2023, 10:53 AM
Viimane postitus: jarxx
  O: M103 3.0 mootor ashton 2 280 17-06-2023, 01:19 AM
Viimane postitus: arturmalcik
  M: W116 mootor kaido66 0 139 20-05-2023, 07:58 PM
  O: M113k mootor või plokk koos sisuga noosik 0 159 18-05-2023, 09:33 PM
Viimane postitus: noosik
