DSP 1.8 + WIFI 56 bit DIGITAL SOUND PROCCESOR (DSP) + WIFI
Analog Devices 56 Bit Digital Sound
Processor (DSP) Burr Brown High-End
Audio AD/DA Converter
Lossless Audio Streaming via WiFi for iOS and Android devices or via USB port for Windows devices.
Real-time DSP Configuration via WiFi or via USB port with any Windows system.
Large overview page for quick check of all actual settings.
Possibility to save and re-load the DSP configuration at a cloud provider.
30 band parametric equalizer
High- / Low- / Band-pass with slopes up to 30 dB / octave
Butterworth / Bessel / Tschebychev filter
Time alignment with up to 4,82 meter (14,6 ms) can be adjusted in 7 mm (0,02 ms) increments.
6 PreAmp inputs
6 High Level inputs
1 Stereo Aux input (3,5 mm jack)
1 Phone / Navigation input with autosense function
1 Mini USB input
SPDIF input / output
(optical, pass through possible)
8 PreAmp outputs
Supports Start / Stop vehicles
Dimensions (LxWxH): 200 x 179 x 40 mm
2.4 GHz WiFi Module with Mini-USB port
For use with DSP 1.8 only
USB-A to Mini-USB-B cable included
Dimensions (LxWxH): 72 x 52 x 25 mm
Töökorras ja komplektne.
HIND: 500.- eurot
Postiga saatmise võimalus!
Saadan nii SmartPosti, Post24/Omniva, Cargobus või kullerteenusega.
Asub Tartus./58 20 2007/ronnythebeast@gmail.com
[Pilt: 16086708_2.jpg]
[Pilt: 16086709_2.jpg]
[Pilt: 16086710_2.jpg]
  M: BOSE sound system W140 Müüdud freeman 0 2,370 03-08-2020, 10:28 AM
Viimane postitus: freeman
  M: SONY 1DIN 7" TFT DVD 2 X AUX-IN 3 X RCA AV-WIFI TÄISKOMPLEKT Ronny The Beast 0 2,487 29-11-2019, 12:56 PM
Viimane postitus: Ronny The Beast
  M: Mercedes-Benz Sound 7000 - 25€ Randoolen 2 3,167 19-02-2018, 10:46 PM
Viimane postitus: Randoolen
  M: Alpine CHA-S624 6CD CD-TEXT OPTICAL DIGITAL OUTPUT M-DAC AI-NET komplektne! ronnythebeast 0 1,876 17-01-2016, 06:16 PM
Viimane postitus: ronnythebeast
  M: Clarion DRX7375RW 4 X 45W 6 X RCA AUX-IN DSP/EQ PUITIMITATSIOONIGA ronnythebeast 0 2,053 29-12-2015, 11:33 AM
  MÜÜDUD! Mercedes-Benz SOUND 3000 originaal-autostereo. ronnythebeast 6 4,995 23-12-2015, 09:19 PM
Viimane postitus: John70
