Race.Fi: Product topic
Model specific suspension listing
Finding the correct suspension parts is now easier than ever! Just select your car's make, series and model, and the shop will show you all the model-specific parts available for it.
[Pilt: promo_suspension-search_en.jpg]
The suspension search shows you all the model-specific kits in one view. Whether it's D2 coilovers, Eibach B12 Pro-Kits or B12 sportline suspension kits, or Eibach Pro-kit and Sportine lowering springs, they're all there.
The model-specific listings make things quicker, and you see everything that's model-specific and available at a single glance.
You can also narrow down the lists with the product brand and go deeper to just springs or coilovers. The shop also has several universal parts in the traditional product categories, like adjustable endlinks and coilover helper springs.
Check out the model-specific suspension listings here:
»» Race.fi: Model-specific suspension kit listings
Have a great weekend!
-Riku
-Riku
Correct rims easily through wheel selector
Wheel selector helps a lot to find correct wheels. Just choose diameter, width, pcs and/or offset. In addition, the rims can also be filtered with different wheel brands.
[Pilt: wheel_selector_en.jpg]
Wheels selector makes it easy to find the correct wheels as almost 150 wheel articles searched by hand is pretty laborious, especially when you know the details. Of course its possible to check the wheels like before from articles or brands.
A lot of wheels and accessories (bolts and nuts) have recently been added to the webshop, for example we added all the Rota wheels and Japan Racing wheel amount doubled to the previous one. Spigot rings for the center bore always comes with all our wheel brands and with Rota wheels, nuts or bolts are also delivered in the package. Usually all the wheels are in european stock, so the delivery time has been under a week in best cases.
Click the banner or this link:
»» Race.fi: Wheel selector
-Riku
Super offer: All Eibach products -10%
Lets put Eibach products in -10% discont for the next week. Probably one of the leading spring manufacturers, Eibach is a certain choice for lowering springs, shocks and kits. Eibach also makes high quality wheel spacers and sway bar kits.
[Pilt: eibach-offer-20190426-en.jpg]
Eibach Pro-kit and Sportline lowering springs
[Pilt: banner_eibach_springs_en.jpg]
Pro-kit and Sportline lowering springs offer superior quality and ride comfort. They are also an OE choice of many factory sports kits from Audi and BMW. Pro-Kits offer drops of around 30mm, and Sportline kits 40 to 50mm.
»» Pro-kit lowering springs
»» Sportline lowering springs
Eibach Pro-kit and Sportline B12 suspension kits
[Pilt: banner_eibach_b12_en.jpg]
The B12 kits come with Eibach springs and Bilstein B8 dampers which offer firm damping and are designed for lower springs. Most models also have an upside-down design for increased rigidity. Most customers change cars from time to time, and this is a kit many get for their new car as well. That's about as high as customer satisfaction can get Wink
»» Eibach Pro-kit B12 suspension kits
»» Eibach Sportline B12 suspension kits
Eibach Pro-street S coilovers
[Pilt: banner_eibach_prostreet_en.jpg]
Eibach Pro-street S coilovers offer a very sporty driveability and a stepless height adjustment, still maintaining a lot of comfort. Offering drops of 20 to 70mm, the Pro-Street S coilovers are a choice of a gentleman seeking the perfect stance.
»» Pro-Street S coilover kits
Eibach Anti-Roll-Kit sway bar kits
[Pilt: banner_eibach_antiroll_en.jpg]
A sway bar kit is the overlooked way to increase stability in cornering without sacrificing any of the comfort. Stiffer roll bars keep the car level in corners, and at the same time allow for softer and more comfy springs - or overall better track performance of course - its your choice!
»» Anti-Roll-kit roll bar kits
Eibach Pro-spacers
[Pilt: banner_eibach_spacer_fi.jpg]
Eibach Pro-Spacers are an excellent pair to go with Pro-Kit or Sportline lowering springs and when the wheel looks lack "it". Spacers will bring out the wheels by the amount of their thickness from both sides. Spacers can be found with specs (pcd, center bore) or with car model, depends does the listing recognize your vechile.
»» Eibach Pro-spacers
-Riku
Japan Racing wheels can be bought also as "custom"
In addition to the standard range of Japan Racing wheels, many wheel models can also be ordered with the desired bolt pattern and ET number as "custom". In this way, models that have run out of stock, for example, may be ordered little bit faster.
[Pilt: wheels_en.jpg]
JR is undoubtedly the most popular wheel brand of this spring, they have a terrific look and the quality is at least very good. Delivery is also quite fast, the wheels that are in the factory stock rarely takes more than one week to deliver at least in near of big cities. As said, several Japan Racing models can also be purchased as "custom", the bolt pattern and the ET number can be decided by you (ET is usually set to a certain range where to choose from).
Wheel offset:
Wheel offset is the distance in millimeters from the hub mounting surface to the center line of the wheel. A positive / bigger offset is when the hub mounting surface is toward the front or outwards of the wheel. Negative / smaller offset is when the hub mounting surface is toward the back or brake side of the wheels center line. Offset can also be zero, then the hub mounting surface is even with the center line of the wheel.
Bigger = wheels sit more inwards.
Smaller = wheels come out more.
Wheels includes also model specific hub centric rings and center cups.
Order Japan Racing wheels from here with comprehensive payment methods
»» Race.fi: Japan Racing wheels
Japan Racing bolts and nuts
»» Race.fi: Japan Racing bolts and nuts
-Riku
Weekie: Eibach spacers -10%
Lets put the Eibach wheel spacers in our weekly offer, with them you will get the perfect look and much better handling. Most popular wheel spacers are usually in our own stock and we can get the fast from the manufactuer anyway, for example with express shipping.
[Pilt: promo_20190510_eibach_en.jpg]
Its possible to look spacers by car model or with wheel specs, so basically if you know what car you are driving, then its easy to find the spacers as well. If the car is not known or it is not on the list for some reason, they can also be searched by bolt pattern, width or center bore and of course its possible to ask our sales for example by email (info(at)race.fi. Spacers are priced as a pair and most of the thickest spacers comes with new bolts/nuts (depends which ones car uses). Of course it makes sense to buy new bolts/nuts for all new spacers (even for thin models). We have listed them separately in webshop with lenght, type and thread.
Aluminium spacers are also much lighter than steel spacers, but they has the same durability anyway or even better. Some of the spacer models are in our or in our suppliers stock and we always try to keep the delivery times fast as possible. Price for the spacers are always for pair, so if you need them front and rear axle, order two sets.
Eibach spacers in our webshop with discount:
»» Eibach spacers
Eibach bolts, studs and nuts for spacers from here:
»» Eibach bolts
»» Eibach studs
»» Eibach nuts
-Riku
Weekie: Kaaz differentials -5%
Lets put high quality Kaaz differentials on a discount in the form of our weekly offer until next Friday. The Kaaz differential is an excellent upgrade to the track and is also a kind of compromise on the street car.
[Pilt: 20180517-kaaz-en.jpg]
Kaaz makes high quality differentials for many race and street cars. There is a wide range differentials for most common Japan and European car like Nissan and Volkswagen. For example Kaaz has a differential for VW 02A and 02J transmissions. Differentials are available with three different ramp angle setups, 1, 1.5 and 2 way. Kaaz differentials are fully serviceable and you can get all maintenance parts from us like friction discs, springs and high quality oils.
Kaaz differential is excellent choice especially for drifting, rally and time-attack, thats what makes the Kaaz mainly a race differential, but of course it can be used also in street racer as a compromise. Availability in Kaaz is usually a week, usually even faster. Kaaz differentials are always supplied with the Kaaz own differential oils, which guarantee the best possible operation in all driving conditions in any time.
Kaaz differential in our webshop with discount:
»» Race: Kaaz differentials
Invoice / Part payments:
Collector: 60 days interest-free payment period. 2.95€ invoice billing cost. Available in webshop.
Jousto: 14 days interest-free payment period, 4.90€ billing cost. Available in webshop.
Mash: 14 days payment period, no charges. Available in Race.fi store.
All invoices can be changed to part payment. More information about the payment methods: Race.fi: payment methods
-Riku
[Pilt: promo_20190528_eibach_en.jpg]
Now´s the chance to get Eibach products with discounted prices, as mentioned the sale includes all Eibach products from ERS springs to nuts. For a complete suspension upgrade you´ll find the Eibach B12 Pro-kit and Sportline very good, as they include shock absorbers and springs for each corner. Ride stability you will get from (in addition to the suspension) Eibach Pro-spacer wheel spacers and Anti-Roll kits. The most sold products are kept in stock and by ordering you will quickly get even the not-so-popular products.
All Eibach products can be found here:
»» Race.fi: Eibach products
Invoice options at race.fi:
Collector: up to 60 days of intrerest fee free payment time. 2.95€ Invoice fee. Available online.
Jousto: 14 days payment time, 4.90€ invoice fee. Available online.
Mash: atleast 14 days payment time, no fees. Available in store.
All payment types can be changed into part payment. More info about payment types: Race.fi: Payment types
Second tuner meet 20.6.2019
Next month, precisely at 20.6.2019 is being organized this year´s second tuner meet and it starts at 6pm. The plan´s familiar - Coffee, sausages, grill and place are on Race.Fi Smile The event is cost free and for everyone.
Place: Race.fi
Link to the event: Tuner meet 20.6.2019
Have a nice day!
-Riku
Weekie: Davies Craig electric water pumps
Lets put the Davies Craig electric water pumps on discount in our weekly offer. Now its a great opportunity to get more cooling for the hot summer, most popular water pump models are in our own stock and we order more at least every week.
[Pilt: dcpumps_20190607_en.jpg]
With Davies Craig electric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body which will handle lots of power if needed, for example in race car.
Its possible to buy water pumps separately or as a set which includes the controller. With controller its possible to adjust water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l and 150l are usually in stock and of course we order more when ever needed.
Davies Craig water pumps in our webshop with discount:
»» Davies Craig eletric water pumps
Collector: up to 60 days of intrerest fee free payment time. 2.95€ invoice fee. Available online.
Next month, precisely at 20.6.2019 is being organized this years second tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill and meeting place are on Race.Fi Smile The event is cost free and for everyone.
Place: Race.fi
-Riku
Why its smart to buy a D2 coilover kit
D2 coilover kit is an excellent choice for street and race, all kit has a height and 36 step damping adjustment - some of the kits has also camber adjustable top mount. Most popular sets are in our stock and others we can get usually in two weeks.
[Pilt: d2_en.jpg]
D2 has gained lots of popularity here in Finland, especially Street kit which is many peoples choice when replacing the old OEM suspension. Height and damping adjustment is excellent for all driving conditions in Finland. In the winter its possible to lift the suspension a little and in the spring lower again for example during the tire change. Damping adjustment gives much more comfort when its possible to adjust the stiffness depending what surface you drive on.
Coilover kits are road legal and we deliver our approval for the inspection, with that only the wheel alignment paper is needed (and of course the car aswell ;D). There is two years warranty on D2 street kits and it also includes the comfort warranty which means that its possible to change the spring + spring rates within 60 days of purchase, charging only shipping costs.
D2 coilover spare parts:
There are lots of spare parts available for D2 coilover kits, including springs, lock rings, dust boots and tools. We keep the most popular ones always in stock and order more regularly.
D2 coilover kits in webshop:
»» Race.fi: D2 coilover kits
D2 spare parts in webshop:
»» Race.fi: D2 spare parts
Place: Race.fi
Have a great tuesday!
-Riku
Coming tuner meets
One tuner meet is now behind and there were a lot of participants, roughly counted we made a visitor record - not a bad start of this year! More is coming, actually the next tuner meet is in next weeks Thursday, date: 20.6 & time 18.00 -->
[Pilt: event-20190524-en.jpg]
Here is an easy list of all tuner meets for this year:
Second meet
Time: 20.6.2018 at 18.00 - 19.30
Place: Race.fi
Third meet
Time: 25.7.2018 at 18.00 - 19.30
Place: Race.fi
Link to the event: Tuner meet 25.7.2019
Fourth meet
Time: 22.8.2019 at 18.00 - 19.30
Place: Race.fi
Link to the event: Tuner meet 22.8.2019
Fifth meet
Time: 19.9.2019 at 18.00 - 19.30
Place: Race.fi
Link to the event: Tuner meet 19.9.2019
Welcome aboard!
- Race.fi staff
Weekie: Quaife Mercedes differentials
Lets put the Quaife Mercedes differentials in discount in our weekly offer, most popular models are in our own stock. Quaife is a great choice especially for our changing weather conditions.
[Pilt: weekie-quaife-mb-20190614-en.jpg]
Now its a great opportunity to get Mercedes differential with better price. Quaife is one of the best modifications for a car and especially for Finnish weathers. According to the customer feedback, the most common is the improved grip when comparing to the original diff, especially in the winter.
Quaife differentials are manufactured and designed in England where the knowledge is in high level and where all the differentials are tested before putting them on the market. Quaife works great even with big amount of snow and with the original traction control, also the "yellow light" does not flash so often when there is more grip. We have lots of differentials in stock and we order more every week.
More information and Quaife Mercedes differentials with discount:
»» Race.fi: Quaife differentials
Place: Race.fi
Link to the event: [url=https://www.facebook.com/events/441636473051812/]Tuner meet 20.6.2019[/url
-Riku
Weekie: Powerflex bushings -10%
Lets put the high quality bushings on -10% discount in our weekly offer. Powerflex bushings offer more stability and durability to driving and they also last usually much longer than OEM bushes.
[Pilt: promo_20190712_powerflex_en.jpg]
Powerflex bushings are great update to replace old rubber bushings from your car, they improve handling and eliminate unwanted suspension flex tremendously. Polyurethane bushing are hard enough to stop unwanted changes in wheel angles but still flex enough for a firm and comfy ride. Powerflex polyurethane bushings are the number one choice when you need more stability and durability to driving, but still want to keep the car comfortable in streets.
Powerflex bushing in our site with discount:
»» Powerflex bushings
Third tuner meet 25.7.2019
This month, precisely at 25.7.2019 is being organized this years third tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill and meeting place are on Race.Fi Smile The event is cost free and for everyone.
Place: Race.fi
Have a nice weekend!
-Riku
Weekie: Holset turbochargers
High quality Holset turbochargers are now in offer until next Friday. Holset turbos are available with different sizes, so they are suitable almost for any petrol and diesel engine.
[Pilt: promo_holset_20190712_en.jpg]
We just put Holset turbochargers in our weekly offer! The Holset HX35 Super 8cm2 "wakes up" comfortably from lower rounds and can be always twisted to the end. The 8cm2 housing fits nicely to 1.6 - 2.0l engines and for larger assemblies we recommend the HX40 and HX50 models, which is suitable even a little bit larger engines.
Holset superchargers are available in both: Water and oil cooled models, both have their own advantages: Oil may be a bit easier to install, but water usually provides a slightly more efficient cooling. Holset turbochargers are always shipped with a model specific gasket kit, which means you don't need to buy them separately, unless the purpose is to grab a few pieces for the future. For more information and assistance in selecting turbochargers, please contact us by e-mail or phone. Most popular turbochargers can be found directly from our stock.
Turbochargers with discount in our webshop:
»» Race.fi: Holset turbochargers
Place: Race.fi
-Riku
Weekend offer: Black Diamond products
Lets put the Black Diamond stuff in discount for this weekend! Now is great opportunity to get brake parts even better price than earlier. Black Diamond also have high quality braided clutch hoses which are easy to install while performing a clutch change.
[Pilt: promo_blackdiamond_20190719_en.jpg]
Black Diamond has a great track record both on the streets and competition on both tarmac and dirt, they can also be used to replace the OEM brakes. Black Diamond brake discs are available in three model, grooved, drilled or with both. The Brake pads have a great grip and low dust level, they can also handle a big amount of heat. With discs and pads we recommend a braided brake hose kit, which is a great final update. Braided hoses make braking more accurate when the balloon-like effects are reduced from the brake pedal. Brake hoses are made from RST, so they handle the Finnish weather conditions nicely Wink
We recommend to use Black Diamonds brake fluid with brake parts so the brakes will run perfectly. Discount is in Black Diamond , but we have also wide range of outlet BD parts with up to -40% off. Most common discs, pads, hoses and brake fluid can be found directly from our stock. We order more parts twice a week and even the most special discs arrive in less than a week.
Check the Black Diamond brakes from our webshop, prices includes discount (up to -40% off):
»» Black Diamond brake discs
»» Black Diamond brake pads
»» Black Diamond clutch hoses
»» Black Diamond brake hoses
»» Black Diamond DOT4 brake fluid
Place: Race.fi
-Riku
Weekend offer: RVS treatments -10%
Lets put the RVS products in -10% discount for this weekend. You will find suitable treatments for engines, transmissions, power steerings and injection pumps.
[Pilt: promo_20190726_rvs_en.jpg]
RVS does not require much demonstration, it is a practically a working products that reduces friction and raises compression pressures (improves gear contact in transmission). Treatments are also high capasity, with one treatment its possible going up to 100,000km and for several years, depending on how many kilometers will come. The weekend's offer now offers you an excellent opportunity to buy treatments as a gift or own stock with much better price. Approximately all the treatments are always available from our stock, but during the offer the shelves are quickly empty - although more products usually comes for a next working day, so they do not have to wait a long time.
RVS treatments with discount:
»» Race.fi: RVS
Fourth tuner meet 22.8.2019
Next month, precisely at 28.8.2019 is being organized this years fourth tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill and meeting place are on Race.Fi Smile The event is cost free and for everyone.
Place: Race.fi
-Riku
Coming tuner meets in 2019
In this year there have been already three tuner meets and every one of them did go really well, thanks to you! But anyhow, we still have two meets left, be there or be a square!
[Pilt: event-20190822_en.jpg]
We will offer coffee, sausages, grill and place Smile Event does not cost anything and everyone is welcome there. Here is the next tuner meet with all the details.
Fourth meet
Place: Race.fi
Here is the last tuner meet in this year:
Fifth meet
Place: Race.fi
Welcome aboard!
- Race.fi staff
Weekend offer: PLX & VEMS
Lets put VEMS and PLX widebands in our this weekend offer. Both are cheap insurances to the engine and for example you can get VEMS with EGT, which will show up to the same screen with the AFR.
[Pilt: promo_20190201_plx-vems_en.jpg]
Today in offer: PLX and VEMS! VEMS + EGT is a excellent wideband for many cars, which has been especially favorite for turbo engines when you will see the exhaust temp from the same screen. We recommend VEMS to any highly tuned turbo car.
The PLX wideband represents a slightly modern package with a touch screen and it also has been one of the best selling wideband a long time. Both of these widebands are also a cheap insurance for the engine when you see it right away if something is wrong - not after something breaks down.
Widebands in webshop with discounted prices:
»» Race.fi: PLX widebands
»» Race.fi: VEMS widebands
-Ari
STRI gauges gives a precise numbers in all conditions
Stri gauges for demanding street drivers and competition use. High quality servo guarantees a precise reading in both conditions. Gauges are available in different led and dial colors.
[Pilt: stri_20190815.jpg]
STRI makes one of the best gauges in the market for sure! Stri DSD series has a fast and precise servo which will guarantee a precise reading even in harsh conditions. STRI DSD series is very popular in track as it runs perfectly and always shows precise numbers.
STRI gauges are very quiet, almost mute - automatic calibration on every start make sure that you can always get right numbers. Stri gauges are available in different background and led colours or with smoke or clear lens. STRI stock focus turned to the 52mm club sport models with a black dial and clear lens as they are the most popular ones. Other STRI gauges we can get fast from Europe, usually in few days.
Check Stri gauges in our webshop:
»» Race: Stri gauges
Place: Race.fi
Have a great thursday!
-Riku
Tuner meet next weeks thursday, 22.8.2019!
In this year there have been already three tuner meets and every one of them did go really well, thanks to you! But anyhow, we still have two meets left, be there or be a square! Next tuner meet is more specifically next weeks thursday (22.8).
Fourth meet
Place: Race.fi
Fifth meet
Place: Race.fi
Welcome aboard!
- Race.fi staff
Big Grin Race.Fi from Finland introduces Race.Fi 66 53,109 21-07-2017, 02:09 PM
Viimane postitus: Race.Fi
