M: Android seade teie mersusse. Koos paigaldusega
Android 4.4 Quad Core 1024*600 Car DVD GPS Mercedes
Sobivus:
Mercedes Benz E-Class W211 E200 E220 E240 E270 E280 E300 E320 E350 E400 E420 E55 E500 2002-2009
Mercedes Benz G-Class W463 G350 G500 G55 2001-2010
Mercedes Benz CLS-Class W219 CLS350 CLS500 CLS550 CLS55 CLS66 AMG 2004-2011
Hetkel paigaldatud üks seade Mercedes-Benz CLS W219 masinasse ja asi toimib väga hästi. Lähiajal ka video seadme tööst.
Koos paigaldusega on hind 400€
Bose helisüsteemiga ja valguskaabel süsteemiga masinatel tuleb lisaks maksta 45€
Muude mudelite puhul esitada küsimused postkasti.
Kontakt: 58800 viis 6 6
Süstemi näitajad.
OS:Android 4.4.4 System
CPU:Rockchip 3188 Cortex A9 Quad Core
RAMBig GrinDR3 1GB
Nand Flansh:16GB
Radio:FM/AM
GPS:SIRF III
Screen:Capacitive Touch Screen
Display Resolution:1024*600
Amplifer:ST-TDA7388
DVD decoder: Sunplus 8202VGQ
Radio: ST-TDA7786
Amplifier IC: ST-TDA7388
Power supply: DC 12v (allowance range: 10.8-14.5V)
Video Decoder: HD 1080P
Radio Parameters
FM Frenqency Range: FM:87.5-108MHz
FM Increment: 0.05MHz(EU)/0.1MHz(US)
AM Frenqency Range:AM: 522-1620KHz
AM Increment: 9KHz(EU)/10KHz(US)
Country: Europe/USA1/USA2/Japan/Russia
Preset Stations: 30(FM 3*6, AM 2*6)
RDS: Yes, On/Off
DVD Parameters
Vidio output range: 1.0V-1.2V(75Ω)
Compatible Disc: DVD/DIVX/MP4/MP3/MP2/VCD
GPS Parameters
Operation system: Android 4.4.4
Support Map: Android 4.4.4 Map
Main Frenqency: 1.6GHz
Map Resolution: 1024*600
Support 2D/3D Map Views: Yes
Voice Guidance: Yes
8GB TF Card included.
Dual Zone Yes, navigating while music playing
Online Nav.Yes, support google maps online navigating
Headrest Monitor Yes, support video output to car headrest monitor while navigating
Bluetooth Parameters
Hands Free: Yes
A2DP (Bluetooth Stereo Music): Yes, can play stereo music through Bluetooth
Bluetooth Music Control: Yes, play/pause/previous/next
PhoneBook-Download: Yes, can download phonebook from mobile to this unit
Phonebook search:Yes, can use the first letter to search contact member in PB-Listings
Calling Records: Yes, Dialed Call, Received Call, Missed Call
Setup: Auto Answer, Auto connect, Device name
Built-in Microphone: Yes, on the front panel
External Microphone Jack: Yes, on the back
USB Port Position On the Back, USB or 3G Modem Port optional
Maximum Capacity 32GB
Play MP5 Videos; Yes, can play RMVB videos up to 1080P
SD card slot Position: On the front panel
3G/WIFI
WIFI: Built in WiFi modem, support IEEE802.11B/g/n compatible WLAN
3G: 3G Modem not included, 3G universal Drive, support external USB
Dongle: WCDMA, EVDO, TD-SCDMA
DTV-INPUT
External Port for TV Box: Yes, Support Analog TV/DVB-T/ATSC/ISDB Box
Power Supply to TV Box directly: Yes, you can connect our TV Box to achieve this function
Touch Control the TV Box on unit: Yes, you can connect our TV Box to achieve this function
Input & Output
Output: Video output*2 / Subwoofer output / Rear output L&R / Front output L&R
Input: Rear Camera input / Video input / Aux input L / Aux input R
Multimedia Parameters
Audio Format: MP3.WMA.MP2.OGG.AAC.M4A.MA4.FLAC.APE.3GP.WAV etc. Could play via song list.
LRC synchronized display; ID3 search; Search by files;Album picture; User-defined audio effect.
Video Format Support AVI(H.264.DIVX.DIVX.XVID). rm.rmvb.
-MKV(H.264.DIVX.DIVX.XVID).WMV.MOV.MP4(.H.264.MPEG.DIVX.XVID).DAT(VCD format).VOB(DVD format).PMP.MPEG..MPG.. FLV(H.263.H.264).ASF .TS. TP.3GP.MPG ect, >=30 formats, playing internet video directly(while downloading).
Up to1920X1080 pixels. 30Mb. Fluent play without light spot.
Picture Format JPG/BMP/JEPG/GIF/PNG…
Others
Torque Pro(OBD2&Car) Yes, you can connect a Bluetooth OBD2 Scanner Tool to use this function
Mirror Link function: Yes, connect to iphone & Android mobile to use this function
DVR Camera input: Yes, connect a USB Camera to use this function
Rear view camera: Yes, Support rear view camera input
Steer wheel control: Yes, Canbus included
https://lh3.googleusercontent.com/-So7ge...25255D.jpg
milline on heliprotsessor?
Tühja-Tähja tootmiskoondis
Müüa Star C3 , Star C4
(14-02-2016, 11:54 AM)madis71 Kirjutas: milline on heliprotsessor?
(14-02-2016, 01:46 PM)Greger Kirjutas:
see on sul lõppvõimendi
heliprotsessor peaks olema :BD37xxx(x asemel on numbrid tähed.seda muidugi saad teada kui sisse vaatad asjaleSmile
kas saan aru et sa oled selle juba oma autole paigaldanud-kas saaks tulla ja heli kuulata?
(14-02-2016, 03:33 PM)madis71 Kirjutas:
Ja saab ikka tulla kuulama. Helista ja lepime kokku.
Kui kiiresti end üles laeb, kui auto käima panna?
Androidil võtab see üldjuhul 30 sekundit kuni minut
(15-02-2016, 09:17 AM)indrek Kirjutas: Kui kiiresti end üles laeb, kui auto käima panna?
see mille ma oma crafter/Sprinterile panin leiab ennast ules ca 20 sekundiga kui süüde väljas kui aga on nupust välja lülitatud siis uuesti lülitades kohe.
(15-02-2016, 10:27 AM)madis71 Kirjutas:
Täpselt nii on.
(15-02-2016, 10:43 AM)Greger Kirjutas:
Täpselt nii on.
kui kedagi huvitab milline mul on siis tuleks vaadata teemat : M:7" Benz Quad Core Car Multimedia System
mul neid mitu tükkiSmile
Kas see seade ka reaalselt integreerub muu elektroonikaga?
- Roolinupud töötavad?
- Telefon?
- Suhtlus Logic7 võimendiga/CDboxiga?
(15-02-2016, 11:23 AM)Blue Chip Kirjutas: Kas see seade ka reaalselt integreerub muu elektroonikaga?
- Telefon?
kuna minu bussil roolinuppe pole siis hetkel veel ei tea kuidas toimib-võimalused seadmel selleks on.
telefon töötab suurepäraselt.
osadel mudelitel on nn virtuaalbox aga reaalselt boksi, minu oma, mis bussil ei juhi-puudub võimalus.
mis nüüd logic7sse puutub siis otse tehase variandis tal puudub aga ma proovin lisa converteriga seda ja kontrollin kõik yle ja annan hiljem teada.
Logic 7 ühendamiseks on vajalik soetada lisa kaabel millest on juttu ka kuulutuses. Rooli nupud toimivad ja on ka seadistamise võimalus. Telefon toimib ning ka tagurdas kaamera lülitub ise automaatselt tagurpidi käigu sisestused. Selle funktsiooni saab välja lülitada.
Makk ühendatakse auto can süsteemi, et kõik toimiks nii nagu peab.
Tere! Kas W215 autosse ka on saadaval?
(15-02-2016, 12:41 PM)Greger Kirjutas: Logic 7 ühendamiseks on vajalik soetada lisa kaabel millest on juttu ka kuulutuses. Rooli nupud toimivad ja on ka seadistamise võimalus. Telefon toimib ning ka tagurdas kaamera lülitub ise automaatselt tagurpidi käigu sisestused. Selle funktsiooni saab välja lülitada.
Kas seade on laokaup? Kuskil näha proovida saaks?
(04-09-2016, 10:27 PM)kolekaak Kirjutas: Tere! Kas W215 autosse ka on saadaval?
Huvitaks ka sama asi. CL55`le suure ekraaniga avasse.
Kui on pakkuda, siis olen huvitatud.
(01-11-2016, 12:10 AM)nostromo Kirjutas: Kas ostsid selle Jaapani avariiliste autode oksjonilt kuid kliendi poolt äraöeldud 8700€ ära? Mis teema lahtise SRS airbagiga oli ja kus paugukohad? Peamised vead?
Sain seda vaid 5 minutit vaadata kuid ega palju ei erinenud 7500€ isendist. Vigu oli ikka kuhjaga.
Oled vist oma jutuga vähe valesse teemasse kirjutanud Big Grin
(31-10-2016, 01:48 PM)hents99 Kirjutas:
vaata http://www.alibaba.com/product-detail/Er...64220.html
  Ära anda: W218 (W204?) Android ekraan 10,25 opentracker 0 156 08-10-2023, 10:10 AM
Viimane postitus: opentracker
  O: MB W211 Android raadio tohoh 0 138 19-09-2023, 07:38 PM
Viimane postitus: tohoh
  M: MB W211 Android raadio Inc555 1 215 31-08-2023, 10:18 AM
Viimane postitus: Inc555
  M: Carplay-Android Auto aktiveerimine CONPO 0 348 11-05-2023, 06:03 AM
Viimane postitus: CONPO
  M: GL/ML (X164/W164) raadio/navi (Android), hind: 200€ P6tu 3 1,063 02-12-2022, 12:13 AM
Viimane postitus: P6tu
  O: CD mängija vanemasse mersusse MAV 0 518 11-05-2021, 04:39 PM
  MÜÜDUD!!! KENWOOD DPX306BT 4 X 50W 4 X RCA USB AUX BT ANDROID iPHONE Ronny The Beast 0 2,216 17-04-2019, 04:58 PM
Viimane postitus: Ronny The Beast
  M: Mercedes-Benz mudelikohased puutetundlikud Android Navi Raadiod malukas 18 24,347 25-09-2018, 10:09 AM
Viimane postitus: malukas
  Müüa Comand NTG 2 + CD Box + tagumine multimedia seade -Hans- 2 3,312 23-08-2018, 06:08 PM
Viimane postitus: -Hans-
  M: Vito, Sprinter Android 6.0 replica raadio swrt2002 1 2,884 09-04-2018, 10:28 PM
Viimane postitus: swrt2002
