  • 1Hääli - 5 keskmine
ASSYSTi (hooldusintervalli arvesti) nullimine
1. kõige pealt võti ACC peale
2. otsid assysti välja ja hoiad nuppu all
3. samal ajal keerad korrax syyte sisse ja siis tagasi ACC peale
4. ikka hoiad nuppu all ja siis 10-15sec ja siis peax piixuma
Turn the key to position 2 in the ignition lock and immediately press
button 000.0 twice within the space of one second.
Turn the key to position 0 in the ignition lock.
Press and hold button 000.0 Turn the key to position 2 in the
ignition lock. Keep button 000.0 pressed.
Service message with current remaining distance or remaining time
appears.
After about 10 seconds, an acoustic signal will sound and the service
display with the new starting distance or starting time appears for
about 10 seconds.
Release button 000.0
Teema on kleepuv ja siia rohkem postitusi teha ei saa. button 000.0 = 0-nupp
EDIT: Kuna sageli kiputakse koos õliga vahetama ka salongi õhufiltrit, siis mainin ära, et see asub peaasjalikult kõrvalistuja jalge all katte taga. w210 ja w202 puhul käib kate eest ära 2 klambriga ja all on piklik (viltu asetsev) moodustis, kust 2 valge klambri kõrvale lükkamisel tuleb filter külg ees välja. Ehk siis filter on vertikaalselt sees.
Roman kirjutas:
2000 to 2002
Sit in the driver’s seat and close the door.
Turn the key to position “2”.
To load the trip odometer and main odometer, press button ‘3’ or ‘4’ on the multifunction steering wheel until the display appears.
Press button ‘5’ or ‘6’ until the FSS indicator appears.
Press button ‘R’ on the instrument cluster for approximately 2 seconds.
The multifunction display asks: DO YOU WANT TO RESET SERVICE INTERVAL? - CONFIRM BY PRESSING R
Press button ‘R’ on the instrument cluster again, and hold until a signal sounds. The message SERVICE INTERVAL HAS BEEN RESET appears in the multifunction display.
The new service indicator displays 10,000 miles (15,000 km) remaining until next service.
"3 ja 4 on menüüvaliku nupud ning 5 ja 6 noolenupud ja R nuppu pidi hoidma umbes 4-5 sek."
On päris ära tüüdanud, et näitab displei peal kogu aeg service võtmekest, kuigi masin tipp-topp korras. Kas seda saab kuidagi mingi nupukombinatsiooniga ise maha võtta või peab diagnosti minema? Masinaks pre-facelift w210 300 turbodiesel ja rool peal nuppe pole.
Abi eest tänud ette.
1. süüde sisse ja vajuta kiiresti kaks korda järjest 0. Seejärel keera süüde välja.
2. Nüüd hoia 0 all ja samal ajal keera süüde sisse ja hoia 0 niikaua kuni kuuled piiksu.
3. Peaks displayl siis näitama 15000km
kombinatsioon toimis kenasti. Tänud abistajale.
  Starteraku laadimise lugeja nullimine >2015 marek 7 1,355 20-10-2022, 12:32 PM
Viimane postitus: marek
  W124 ASD testimine ja vea nullimine Sm. Västrik 15 32,826 02-03-2011, 02:11 PM
  W208 99a CLK assysti reset Preda 0 2,452 08-07-2009, 07:59 PM
Viimane postitus: Preda
