300E24 1991W124
Sai miski hetk tagasi hangitud uuem Mercedes-Benz. Hankimise pöhjuseks oli eelmise (mitte Mercedes-Benz) auto vaevaline liikumine. Mercedes-Benz otsa komistasin juhuslikult.
Remontima polegi vist vaja hakata enne kui aasta löpus, talvel hooldus teha.
Load kadusid taskust 6 nädalaga, varsti saan tagasi. Crybaby
Mark:  Mercedes-Benz 300E24
Väljalaskeaasta: 1991
Läbisõit: 256 000 km (?)
Võimsus: 162 KW -220HP
Mootori valem: 3,0 R6
Muud: Sportline, Eber puldiga. Veljed on ja pysivad 15 tollised, rehvid 205/60 (210kmh)
Vigu veel leidnud ei ole. Ehk siis ostsin auto, söitsin 5000 km ilma miskit tegematta.
Sisu on tumehall, istmed blüüs ja terved, va juhiiste. Armatuuris pragusid pole, istmed terved ja sirged.
Kerel 2 rooste kohta, aga midagi läbivat pole.
Siia veel vene saidi varustuse list:
VIN WDB1240311B438xxx
Model 300 E-24, AMG 300 E 3.4
Chassis 1240311B438566
Engine 104980 10 004943
Transmission 717450 01 763320
Order 0 0 227 03626
Delivery date 11.01.91
Dealer Nuernberg branch (227)
Interior fabric gray or alpaca gray (078)
Paint 199 metallic blue-black (с 01.01.1983)
Options
244 sports seats, front (с 01.07.1986)
281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
531 automatic antenna (с 01.01.1963)
585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970)
592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
650 sports chassis with 15-hole light alloy rims (с 01.12.1988 по 28.02.1993)
673 high-capacity battery (с 01.01.1964)
731 wood trim, burred walnut root (с 01.08.1980)
751 Becker radio Grand Prix 2000 vk RDS (с 01.06.1990 по 31.03.1994)
951 rotating emergency flasher, front (blue light)
sportline (consisting of codes 65/0, 244, 281)
Originaalist on siis olnud 3.4 200kW AMG mootor nagu VIN kood näitab? Või on seda siiani?
See asi on minule siiamaani selgusetu. Vöimalikud seletused:
1. Vene win dekooder jagab seda AMG-d lahkelt köigile 300E24 -dele. Ehk siis, ei ole AMG.
2. Sinise vilkuri röhuvooliku leidsin kapoti alt yles, kes teab äkki oli ka mootor sipa järgi aidatud operatiiv masinal. Yks öli kleps oli mootoril 10w60 Icon_eek
Miski sebimine selle AMG -ga oli 1991 - 1992 aastal oli, vist nagu "proovimine". Ametlikud AMG -d tulid alles hiljem.
Löplik töde selgub alles dyno testis, sygise poole plaan minna, see näitab palju remonti, hooldut vaja teha on.
Mul VIN kood annab sama rea, mis sul: "Model 300 E-24, AMG 300 E 3.4"
Googeldasin ja lugesin igasugu foorumeid, aga lõplikku vastust sellele ei saanud. Kuigi võrreldes ühe AMG mootori pildiga, mis netist leidsin näeb mootor identne välja, ainult ühtki AMG kirja ei leidnud katetelt.
Vabanda väikese OT pärast , kuid:
Millised visuaalsed erinevused üldse on 3,0 162kw ja 3,0(3,4) 200kw ?
Kas keegi on lahti arutanud, mida see "Model 300 E-24, AMG 300 E 3.4" täpselt tähendab?
Erinevus on ainult see, et õhufiltri korpuse peal on suurelt amg kirjas ja kuskil peaks mõngi silt ka viitama sellele.
