01-03-2009, 12:25 AM
kas keegi tarkadest äkki seletax laiali mida tähendavad w124 koodid 603 ja 800....
varustuse koodid
01-03-2009, 12:40 AM
603 - headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (from 01.08.1971)
800 - Change of year of model, last figure shows new model year
01-03-2009, 12:20 PM
eDiCk Kirjutas:603 - headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (from 01.08.1971) last figure of what? mul 603 näitab: la 7-spoke design 17 zoll ;evolution:????
01-03-2009, 02:16 PM
viimane number näitab mis aasta facelift autol on. Näiteks 804 - 2003 aastal toodetud autol on 2004 a tuled, sisu jne.
01-03-2009, 02:17 PM
intsuonu Kirjutas:eDiCk Kirjutas:603 - headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (from 01.08.1971) kuule iga vin-iga näitab erinevad asjad kas ei ole mõistlikum vin-kood siia panna
01-03-2009, 10:55 PM
(Seda postitust muudeti viimati: 02-03-2009, 11:28 AM ja muutjaks oli intsuonu.)
eDiCk Kirjutas:intsuonu Kirjutas:eDiCk Kirjutas:603 - headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (from 01.08.1971)
02-03-2009, 01:01 AM
küsi mis sind huvitab
VIN WDB1240911F123248 Model 300 TE-24,AMG 300 TE 3.4 Chassis 1240911F123248 Engine 104980 12 000945 Transmission 722359 03 280761 Order 0 9 569 39358 Delivery date 21.09.89 Dealer Sweden (569) Interior cloth grey (068) Paint 568 signal red (T) (с 01.01.1963 по 31.12.1993) Options 211 automatic limited slip differential (ASD) (с 01.07.1984) rear axle with automatic limited slip differential (ASD) 236 special lamp switching - daytime running lamps (с 01.04.1985) special light wiring for Norway and Sweden 240 outside temperature indicator (с 01.03.1982) 341 additional lamp (с 01.09.1982) 412 electric sliding roof with tilting device (с 01.07.1983) 420 automatic transmission, floor shift (с 01.01.1963) 524 paintcoat preservation (с 01.01.1964) 534 antenna, mechanically operated, without radio set (с 01.01.1963 по 30.11.1990) 593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972) 603 headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (с 01.08.1971) 620 emission control system vehicles with catalyst technique (с 01.03.1985) 673 high-capacity battery (с 01.01.1964) 800 Change of year of model, last figure shows new model year 812 rear-mounted loudspeaker (с 01.11.1974) 825 873 seat heater for left and right front seats (с
02-03-2009, 11:43 AM
eDiCk Kirjutas:küsi mis sind huvitab kysimus oligi selles 603-es..siin näitab üht a olen vaadanud ka mujalt seal see teine jutt..ja see 800.. kui saan õigesti aru siis kuna viimane 0 siis õige aasta on 90..paranda kui eksin..
02-03-2009, 12:02 PM
ei
see on uuem aasta mudel, näiteks restyle ja mitte restyle
02-03-2009, 12:28 PM
eDiCk Kirjutas:ei kusagilt näitas:year of modification 99/1.... |
S 210 hüdroamortide osade koodid? | kriipspois | 5 | 3,756 |
17-12-2014, 10:48 PM Viimane postitus: kriipspois |
w211 varustuse kood 485 ja 551?? | max07 | 7 | 4,898 |
23-02-2009, 12:05 AM Viimane postitus: eDiCk |
