M: Alpine+Dls helisüsteem MÜÜDUD
Pakkuda komplektne helisüsteem.
Makk:
Alpine CDE-9880R Features:
Full Speed Connection for iPod (optional KCE-422i required)
Bluetooth ready (optional KCE-300BT required)
USB Capability for Music File Playback
CD Text Display and Scroll
MP3/WMA/AAC playback
CD-R/ CD-RW Compatible
Quick Search
1-bit DAC
ID3 Tag Information Display
Zero Data Mute (0 bit Mute)
Connectivity
OEM Steering Remote Control Ready
AUX-IN (with KCE-236B)
Power Specification
50W x 4 High Power Amplifier
3 Preouts with Subwoofer Level Control
Display
Dual Illumination (Green/Amber)
5x9 Dot Matrix Display
White LCD Lighting
Audio Processing
Subwoofer Level: -7 ~ +7 dB
Bass Level: -7 ~ +7 dB
Bass Frequency: 60/80/100/200 Hz
Bass Q-Factor: 1~4 (1=wide, 4=narrow)
Treble Level: -7 ~ +7 dB
Treble Frequency: 10/12.5/15/17.5 kHz
High-Pass Filter: 80/120/160 Hz
Other Highlights
MaxTune Tuner
Rotary Encoder Volume Control
Detachable Face Plate
Remote control ready (not included)
ISO Connector Ready
Kõlarid:
DLS C4 Komponent
Suurus 10 cm MAX 80W RMS 50W
2-Ribaline komponentkõlar (asendatud C6 tweeteri ja filtriga)
Suurus: 10 cm (4"); TW: 20 mm (0,8") silk dome
Võimsus: 50 W RMS / 80 W max
Sagedusala: 65 - 20.000 Hz
Tundlikus: 92 dB (1W/1m)
Paigaldussügavus: 58 mm ( 2,28")
Paigaldusava: 102 mm (4")
Filter: LP: 6 dB & HP: 12 dB slope
DLS C6 komponent
Suurus 16,5 cm MAX 90W RMS 60W
Suurus: 16,5 cm (6,5"); TW: 20 mm (0,8") silk dome
Võimsus: 60 W RMS / 90 W max
Sagedusala: 50 - 20.000 Hz
Tundlikus: 93 dB (1W/1m)
Paigaldussügavus: 63 mm
Paigaldusava: 146 mm
Alpine SPE-17C2
Peak Power 210W
RMS Power 35W
Frequency Response: 35Hz - 25kHz
Sensitivity: 91 dB/W(1m)
Air-Vented Lightweight Frame Design
Hybrid Pearl-Mica Injection Woofer Cone
Soft Butyl Rubber Edge
Square Voice Coil Wire Design
20mm Soft Dome Neodymium Tweeter
Alpine 12'' subwoofer SWE-1243IB
Tootja: ALPINE
Ilma kastita paigaldamiseks
Max võimsus: 650W
RMS võimsus: 200W
Sagedusvahemik: 35Hz - 1kHz
Tundlikus: 89.5dB/W (1m)
Paigaldusava diameeter: 282mm
Sügavus: 152 mm
Kaal: 2 kg
Võimud:
Vibe slick a4 2000w
4-channel Amplifier (bridgeable into 2 or 3 channels)
RMS output @ 4ohm: 4 x 150w
RMS output @ 2ohm: 4 x 250w
RMS output @ 4ohm: 2 x 500w (into 2 channels)
RMS output @ 4ohm: 2 x 150W + 1 x 500W RMS (into 3 channels)
Total Max power output: 2000 Watts
Signal to Noise Ratio: 98dB
Dimensions: H 65 x W 545 x D 245mm
Frequency Response: 10 - 20KHz
Crossover type: LP / HP / Flat
Crossover range: 55 - 5500Hz
Super Slick design with rubberised finish
Twin end caps for stealth connections
Soft turn on feature
In dash bass boost remote control
0 - 180 phase control
18db bass boost
Built in relay protection
Selectable HP / LP / Flat crossover
High quality surface mounted components
Double sided PCB
Preouts for linking additional amplifiers
Lo-level and Hi-level inputs
Alpine MRP-T222 250w
General
1/2 Channel Operation
BassEngine�
Subsonic Filter
Bass EQ Circuit
Crossover (HP/LP)
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
Double Buffered Pre-Amp Input Circuitry
STAR Circuitry
MultiMode�
Top Mounted Blue LED Power/Status Indicator
Duo B Feedback Circuitry
Continuously Adjustable Gain Control
Speaker Level Inputs
Gold Plated Power Screw Terminals
Gold Plated Speaker Terminals
Cross-Vented Chassis Design
SPECIFICATIONS
CEA-2006 Power Rating
CEA-2006 Power Rating (40hm at 14.4V = 1%THD+N), S/N 60dBA (Ref. 1W into 4Ohm): 50W x 2
RMS Power (at 14.4V THD+N, 20Hz-200Hz)
Per channel into 4 ohms: 50W x 2 (0.08% THD)
Per channel into 2 ohms: 70W x 2 (0.3%)
Bridged 4 ohms: 140W x 1 (0.3%)
Total Max. Power: 250W
BassEngine� Sound Tuning
Crossover Network: 18dB/oct
Low/High Pass Crossover Frequency (Fixed): 80Hz
Subsonic Filter (Fixed): 20Hz
Bass EQ Frequency (Fixed): 50Hz
Bass EQ Level (Adjustable): 0 - 12dB
General
Power Requirements: 14.4V DC (11V to 16V)
Frequency Response: 10Hz � 50kHz (+0, -1dB)
Signal to Noise (S/N): 100dBA (referenced to rated power)
Input Sensitivity (For Rated Power): 0.2V to 4.0V
Slew Factor: Greater than 5
Input Impedance: 10k Ohm
Speaker Impedance: 4 or 2 Ohm (Stereo), 4 Ohm (Bridged)
Dimensions (WxHxD): 172mm x 60mm x 267mm
Dimensions (WxHxD): 6-4/5� x 2-2/5" x 10-1/2�
Weight: 1.95 Kg. (4 lbs. 5 oz)
Kondekas on olemas, aga ei leidnud väga infot mida lisada. Panen pildid.
Pärit w124 kupeest, mille järgi on tagumised kõlarid ja woofrid ka ehitatud.
Defektidest rääkides, siis ühel DLS C6 elemendil on membraanis väike pragu ja C6'te katted/võred veidi kannatada saanud. Ühel woofril klemmi ja membraani vaheline juhe parandatud ja liigib intensiivsemalt. Mõni juhtme ots veidi mustaks tõmmanud. (mõni välja vahetada)
Kaasa siis kõik vaja minevad juhtmed (ka kõlari juhtmed) + USB kaabel.
Arvestasin, tutikate elementide ja võimude hetkelist kogu maksumust (kes, kus lehelt leiab) siis tuleks see hind kuskil 1200-1400 euri.
Kasutatud müügil oleva tehnika eest tahan 700 EURI.
Kahjuks kuulata pole enam võimalik, võtsin masinast välja, aga saan mõned telefoniga tehtud videod siia lisada+ pildid komplektist.
56288053
Aare
https://www.youtube.com/watch?v=2bEqH3-jmSY
https://www.youtube.com/watch?v=CADNQ9lzZsw
https://www.youtube.com/watch?v=YKy29Mlw_KI
https://www.youtube.com/watch?v=1_HMWcK9bKU
http://public.fotki.com/AAljasmets/dlsal...elissteem/
Seda tagupaneeli eraldi ka saaks Smile ? Ilma elementideta.
Autoremont/hooldus/Helitehnika Viljandimaal - 5585756
Sain just komplektselt selle asja müüdud Smile
See tagumine paneel on tehtud saepuru plaadist ja soome papist, head nokitsemist Wink
kui soovi , siis võin mõõdud öelda. Ilmselt rohkem kuidagi aidata ei saa.
Hästi Smile a ei nokitsemine meeldib endale ka aga kuna valmis asi oli pakkuda siis mõtlesin minna kergemat teed pidi. Mõõte vast pole väga vajagi, teen vana aluse järgi šketsi ja lasen loovusel lennata.
Kuidas muidu freeairid mängisid aknalaual ?
Pole kaua siia sattunud!
Endiselt tundub mulle, et freeair ainuke reaalne bass autos ongi, keegi ei torgi noaga selga kui muusika mängib ja müdistab õli vägevalt!!!! Smile vb leidsid ehk youtube videod.
  Müüdud: Rariteetne Becker Mexico Cassette audi 0 506 14-11-2021, 01:10 PM
Viimane postitus: audi
  MÜÜDUD:Viseeo MBU-3000+ bluetooth moodul kait 4 780 12-09-2021, 10:39 PM
Viimane postitus: kait
  MÜÜDUD!!! M: BECKER GRAND PRIX KASSETT-RAADIO ronnythebeast 0 868 01-06-2021, 10:49 AM
Viimane postitus: ronnythebeast
  Müüdud Taffinaff 3 1,479 23-03-2021, 05:33 PM
Viimane postitus: Zlang
  ///// ALPINE SWD-2030 AKTIIV-SUBWOOFER 350W CLASS D ronnythebeast 0 1,506 07-03-2021, 09:27 AM
  ALPINE SPG-12KIT NOM 250W RMS MAX 800W 12" 2/4 OHM KOMPLEKT ronnythebeast 0 2,526 07-03-2021, 08:38 AM
  MÜÜDUD!!! BECKER INDIANAPOLIS PRO KOOD OLEMAS! ronnythebeast 0 1,231 17-02-2021, 11:31 PM
  MÜÜDUD!: Becker Europa Cassette 730 audi 0 2,518 10-08-2020, 03:02 PM
  M: BOSE sound system W140 Müüdud freeman 0 2,383 03-08-2020, 10:28 AM
Viimane postitus: freeman
  MÜÜDUD!: BECKER EUROPA CASSETTE 591 audi 0 4,251 11-03-2020, 10:36 AM
