M: AUTEL MaxiBAS BT506 / aku / starteri / generaatori / tester - 200€
Seade täiesti uus ning originaal!
Antud mudel ühildub nii iOS/Android kui ka Auteli seadmetega.
Võimalik diagnoosida elektrisüsteeme: akut, starterit, generaatorit.
[Pilt: 1.jpg]
[Pilt: 2.jpg]
[Pilt: 3.jpg]
[Pilt: 4.jpg]
[Pilt: 5.jpg]
[Pilt: 6.jpg]
[Pilt: 7.jpg]
[Pilt: 8.jpg]
FUNKTSIOONID:
• Includes Connected Cable with Clamps
• Test 6- and 12-Volt Batteries: 100 - 2000 CCA
• Test 12- and 24-Volt Cranking/ Charging Systems
• Download Free App from Google Play and the App Store
• Test FLOODED, AGM, AGM SPIRAL, EFB and GEL Batteries
• Battery Health Report/ Temperature Compensation / Cloud-Based Service
• Battery Ratings: Compatible with CCA, CA, MCA, JIS, DIN, SAE, IEC, EN, EN2, BCI, GB
• Support In-Vehicle and Out-of-Vehicle Testing of Passenger Vehicle Batteries
• Out-of-vehicle Battery testing
• In-vehicle testing of Battery, Starter, Charging system voltage (not amps)
HIND: 200 €
Tel: +372 5888 1445
  OSTETUD: W414/W168 Vaneo/A klass generaatori, 2003a, jahutusega Lexuz 0 59 09-05-2024, 02:43 PM
  M: AUTEL MaxiBAS BT506 - aku/starteri/generaatori tester - 125€ OBD 0 79 14-04-2024, 07:30 PM
Viimane postitus: OBD
  M: AUTEL MaxiBAS BT506 - aku/starteri/generaatori tester - 125€ OBD 0 83 29-01-2024, 09:22 PM
  M: AUTEL MaxiBAS BT506 - aku/starteri/generaatori tester - 125€ OBD 0 101 09-11-2023, 12:22 AM
  M: AUTEL MaxiBAS BT506 - aku/starteri/generaatori tester - 125€ OBD 0 109 13-08-2023, 02:16 PM
  M: AUTEL MaxiBAS BT506 - aku/starteri/generaatori tester - 125€ OBD 0 95 28-05-2023, 07:06 PM
  M: AUTEL MaxiBAS BT506 - aku/starteri/generaatori tester - 125€ OBD 0 154 15-04-2023, 05:12 PM
  M: AUTEL MaxiBAS BT506 - 150€ OBD 0 149 15-03-2023, 10:02 PM
  M: AUTEL MaxiBAS BT506 - 175€ OBD 0 166 29-01-2023, 04:08 PM
  M: AUTEL MaxiBAS BT506 - 175€ OBD 0 179 03-12-2022, 05:50 PM
